Hello I have been trying to do words in a row like Week1, Broncos, Home Chiefs problem is week I fills perfect Broncos and Home have double word and Chiefs looks normal. Doing fill on all. If I dow a picture this don’t happen
It seems to me that the problem is either mechanical play or speeds above what the machine can handle, after paying attention to the image. Without knowing the engraving method “fill” or “flood fill” and how it appears in the preview window, it becomes difficult to offer more coherent help.
If you are willing to share the file, I or any other member can guide you in the right direction.
Information about the machine being used also helps.
No “or”, this is backlash. Here is a posting that describes it pretty well.
And here is a posting that explains what has happened.
Yes, you are absolutely right. Assuming the engraving method is individual, it’s quite likely that the backlash effect will reveal.
Without the file to evaluate the variables, I only mentioned what I remembered most quickly.
Yes, you are absolutely right. Assuming the recording method is individual, it’s quite likely that the backlash effect will occur.
Thank you for pointing it out. ![]()
The image that was published did not describe what is specifically intended to draw attention to what was highlighted between the lines.
I will give my opinion starting with the settings.
In terms of speed, for my specific machine, it is likely that I am exceeding the safe limit for problems of this type. But my machine is one of those cheap Chinese ones that has undergone improvements over time. As the structure remains original, I believe I cannot demand more from it for that reason. That is, in your case, which I believe is a much better machine than mine, it seems to me that in terms of the engraving “Fill” settings everything will be ok.
The settings that intrigue me have to do with the scanning offset adjustment.
Why do you have so many repeated entries, and are the values entered in “Line shift” in mm or inches? This parameter is related to the acceleration and deceleration of the laser module. That, eventually, if the acceleration and deceleration values are too high, it is likely to cause oscillations that result in misalignment. But not sure. ![]()
Now evaluating the posted image.
In red - A bump. This looks like debris, on the belt or track, degraded bearing(s). Something that caused a repeated rebound in this area.
In yellow, I believe what you are referring to has to do with the tone. If the material is plywood, as it seems to me, it is very likely that this happens. Being an organic material, don’t expect homogeneity in a recording. Issues such as the wood grain, for example, will create differences in tone. The softer areas of the wood, those that absorb more heat, will burn more than the areas that dissipate more heat.
In blue, the problem you complained about. After what has already been mentioned and what I have been able to analyze, I would check the acceleration values and confirm a third time mechanical issues in the machine.
@Kuth is correct as well. There are multiple issues illustrated in the images. Cure the mechanicals first, then work on the Lightburn settings.
I expect the scan offsets were an attempt to correct backlash problems.
Hello sorry that I am not explaining things right. This all just started. When I do a fill on any letters, numbers I get the middle letters are double like in blue box. As for offset numbers don’t know where these came from I didn’t put them in and when I removed them it didn’t change anything. I just don’t understand when I do a design it don’t do it just letters.
My laser is Xtool pro 20w. I have cleaned and checked everything. No lose belt and laser don’t move.
I am going to try lower speed and see what happens. I would think if it was the machine other things I do would be off also. If I do the same words in line mode it’s not off. Sorry
You can disable the Scanning Offsets and test.
Afraid that something might get lost in translation, I’ll try to explain my point of view based on the images you posted.
The machine is configured to move the laser module at 5588 mm/min with a power of 30% of the laser’s capacity.
This (5588 mm/min) is the speed at which the module moves while the laser is engraving. However, in addition to this, there is the speed of movement while not engraving, and the acceleration and deceleration speeds. I don’t know the values of these and I can’t simulate them because these values are different (or may be) from machine to machine.
You will probably see what I’m referring to by using the “Play” button in the “Print Preview” window.
While the laser is engraving a portion of the letter, it moves at the speed you enter in the “speed” field. However, when the laser moves to the next letter to engrave the corresponding portion, the module will accelerate to a travel speed that is configured in the controller board parameters, and decelerate to the engraving speed to engrave the portion of the letter according to the settings you entered.
This will create a series of consecutive accelerations and decelerations in the direction the module moves. Due to the module’s inertia as a whole, I deduce, with mechanical problems the laser point ends up outside the location it should hit.
When engraving a section (image, for example) that does not expose the laser module to this condition, the problem will not be revealed, or if it is revealed, it will be in a much more subtle way.
An experiment you could do to MASK this problem (not solve) would be to disable the bidirectional direction in the layer settings. Obviously, the engraving time will increase, but if I’m correct, the problem will always manifest itself on the same side. That is, if the laser misses the target (letter) while moving from one letter to another, the error will always be in the same direction, which ends up masking an existing problem.
If the engraving improves with this change, I have no doubt that there is a mechanical problem on the X-axis.
From what I’ve researched, I believe the laser module is based on three bearings.
I believe you’ve already done this, but confirm that there is no twisting of the module in the area where the problem manifests itself. Imagine a minimal defect in thickness or warping in the arm (rail) where the defect manifests itself; the laser beam will oscillate and miss the target. Something that creates this type of defect can also be a loose screw fixing the toothed pulley of the motor, but normally in this case, the defect manifests itself in all or almost all of the recording area.
I hope I was able to help, or at least better understand the problem, in this post that’s already annoyingly long.
You have explained it perfectly. “This all just started” is a classic sign of mechanical issues.
Did you notice the left batch of lines align on the left, and the right batch align on the right? But the center ones do not align on either side? Backlash.
Burn a circle as large as your machine can produce. Use the highest speed you can, and enough power to leave a mark. Take a picture and post it in a Reply.
Yeah, same here. Do it again, but with more power or less speed this time.
Okay, that looks good, but now for the real test. You will have to make some adjustments in this file to adjust for your particular laser.
Make this as big as your laser will allow, and run it at the highest speed you can, to get marks, using 100% power.
Backlash.lbrn2 (78.0 KB)
That is not the file I sent.
The line is thinnest at zero on both scales, at least that is what I see. I would have to introduce backlash to make sense out of that pattern.
Did you have a problem running the provided file?
