Change material library with laser?
I hope I’m not missing something fundamental here, but is it possible to have the library automatically changed based on the laser your working with? I have a fiber with 4 lenses, a co2 and a diode. each obviously needing very different material settings. i have forgot to change the library several times and caused issues, it seems it would make sense for the library to automatically change based on the laser selected.
Which version are you using? If you’re using the lastest version of LightBurn, when you change lasers, the material library should be automatilcally changing.
Check this post for how this can work:
And this one:
Thanks guys, I’ll do some more testing! Maybe I’m screwing something up on my end!
