Hello all. I just changed PC because my old one died. I have successfully downloaded the software and added my machine and laser, but I can’t get anything to burn. The laser comes on and appears to be working correctly, but it will not burn anything. I never had this issue with the old cpu. I am hoping it is a setting. I have slowed it down to extremely slow and went all the way up to 100% power. Still nothing… What should I do?
Edit:
A little more info: I have a Chinese diode laser 15w 450nm. I am using the latest version of lightburn I assume, as I just downloaded it. I am trying to burn simple arial font. I have tried different types of wood at different speeds and power settings. As for the settings in lightburn, I have no idea how to tell you what I have. On the console it says grbl 1.1g. My laser is connected to an openbuilds blackbox.
Did you enable the laser in the device settings?
You could be in beginner mode. It’s shown at the top of the screen.
You can post pictures, generally, is you feel they will help, like worth a 1000 words
If you new here, it might not be possible. But you can put a photo on your Google drive and put a link here to it.
Not sure what you mean here. What appears to be working correctly?
The laser lights up and clicks on and off. I can see the beam, but it won’t burn anything. I will check the other suggestions and thanks for the reply!
Still no luck. It’s like the laser is coming on but doesn’t have the power to burn anything. Almost like when you click fire to see where you are located on the stock…. It’s like the power is not being sent to the laser.
I have a couple of these laser heads but they basically have B+, ground and PWM that controls the intensity. If it’s working at low power for framing, that would indicate that the PWM part of the controller hardware is ok. To turn it on at a low level requires that % PWM.
I noticed that you have $10 set to zero, this blocks much of the information sent to the controlling software such as current position. I think at minimum it should be 3. Maybe someone else can chime in on that. Don’t think this is an issue now, but you should be aware.
I have a blackbox controller from openbuilds (not sure if you are familiar). From my understanding, it is basically an arduino uno with drivers. Two of the wires from the laser are connected to the “tool head” connector on the blackbox. The other two to b+ and b-.
I assume the two wires coming from “tool head” are the pwm output. I checked them with a volt meter while a job was going, and the voltage bounced around from 0v-about 4v. This seemed to me to be correct, as I assume 0v is off and 5v is full power.
At 4v I would think it should be burning, but nothing.
Has my diode laser gone bad? Even though i can see the light and it appears to be working?
It’s hard for me to tell exactly. What I do know is that they take Power and ground for the hardware to function, since it’s not just your signal that does it.
Next the PWM is what tells your laser when to fire and how hard. Sounds like you have that handled.
If you pull that line to a logic high, the laser should fire full power.
So you are reading a varying voltage, it’s indicating the PWM is probably working.
The kind of leaves it to be the laser itself Sorry…
Ensure you are getting full power supply voltage and current to the diode. At least ensure it’s available. Can’t think of much else you can do…
Still having no luck. So, I should be able to put 12v (power and ground) to laser and 5v to the pwm wire (yellow?) and test the laser. This should be 100% power coming out of laser correct?
that is correct but you do have to have the ground from the 12V power also connected to the ground of the 5V power supply.
Since you had said your laser worked perfectly fine before your computer crashed and you setup a new computer with LightBurn, I would not even be looking at or messing with your controller hardware.
FYI, if it was Microsoft Windows which crashed on that computer and you decided to just get another computer instead of trying to fix it, then you can probably boot Linux off of a USB thumb drive and maybe recover your previous LightBurn preference file. Thousands of people and probably more than that have used Linux to rescue filed Windows systems so there are lots of HowTo’s online for doing this.
Also, do not run your laser for very long at 100% power. Just a quick test only. FYI, you should also make sure you have your machine running at the same speed as you were used to because if it is running much faster than before it will burn much less even at the same power setting. You can also look at your Machine Settings to see if anything looks off( max power setting , min power setting, etc ) and also look at your defaults for the layer settings.
So, I tested it with the grounds connected together to the same 12v/5v supply and the pwm connected to 5v. The laser lights up as it should, but still will not burn anything… I assume this means bad laser or laser driver?
Is there a way to tell which?
Is it worth trying to fix?
The pwm tied to 5v will set the laser output to maximum.
If it’s focused and full power then the problem is from the laser input to the diode itself, i.e. the laser itself. Probably not user serviceable. I think you’ll probably be purchasing one.
How long have you had it and how hard did you run it? Just curious.
It must be well focused and I would look at the 12V while it is firing to see that it stays at 12V and is not being pulled down due to high power requirements and weak power supply.
I have had the laser less than 1 year. I never ran it over 90%. I have only used it as a hobby laser. I would say very mild use. I don’t know what else to try to see if it is the laser. I have tried two different power supplies. I would think with 12v supplied to module and 5v directly to the pwm wire the laser should be burning. I am not sure how to tell if it is the diode or the driver however….
Thanks!
I believe that’s the $30 value, which If it’s what I recall, is and should be 1000. Good idea, most of this is configuration… I just don’t think he wants the problem to be a diode failure. He’s been dodging around it for two months… Maybe he’s right
I just assumed there must be a driver to control the power the laser puts out. I know there is a small circuit board below the fan of this laser. Just wasn’t sure if this was replaceable. I was thinking some people buy a diode and a compatible driver and built their lasers to be controlled by arduino?
You are exactly right. I have been hoping it wasn’t the diode, but I think I am just going to have to bite the bullet and get another.
Do you guys recommend any in the LOW price range? I was happy with the performance of this one, but not so much the longevity……
