Check for Update Error Message
When checking for update, TLS initiation failure message. Is that a local problem? If so, how may I fix it?
Download and install manually.
After install if you´re license is active it will install as full working Lightburn.
Please note I am getting a TLS error as well - trying to “check for updates” on version 1.501. I will try the manual download thing but sure seems kludgy.
This is a known issue with the 1.5.01 release and has been fixed. You should be able to download the latest from here.
