Chinese 80W Water Leak flow sensor Failure (update)
Are you still getting the slop error?
If you get the slop error, look at the origin position on the Ruida screen, that is where it’s going to ‘layout’ your artwork. It is the x, y what kind of numbers do you have? and what is the size of the artwork?
Jack I am doing as you say watching the Ruida controller and not getting any error messages thats whats confusing me, if I had a slop error at least I could do something, but nothing but 2 beeps
when I watch the dashboard on my car, a light will come up called check engine this gives you a diagnostic code, through a plug in and will tell you whats happening, this is whats needed on Ruida,
Usually that means it’s done… it’s trying to tell you something.
I am at a loss without some kind of visual.
Drop the .lbrn2 file on the reply window and I’ll look in there and see what I can see…
Can you do screen shots?
you have me with all your tech stuff, whats the LBRN2 file, and screen shots of what the RUIDA console
Hey Jack got my machine working , used an old program from 8 months back and she cut, 3 inches missing off one side and did not cut all the way through, F rame Slop message came up, and pressed enter and away. made another simple program Hello, and was able to Frame where I wanted, still not cut through but I vcan work with this. Sam
If you have a slop error it will not perform like you should expect.
Find out what’s causing the slop error. It’s an error because it knows it cannot do what you ask. I’d suggest NOT skipping these messages, you will eventually damage something, material or machine.
That is how you learn, by correcting ‘errors’ you get more of an understanding of how they work and are better at fixing issues on your own…
