Walt530
(Walt Spadacini)
1
All the circular array does is copy the outside circle of clock face won>t copy tick marks
Dskall
(D Kallenberger)
2
Need to see something to help us out.
thelmuth
(Tim Helmuth)
3
Your selection order matters. Select tick mark, then shift select circle and open circular array tool.
Walt530
(Walt Spadacini)
4
That worked great, thanks
Next problem, how do I close an open shape
parsec
(FerAS)
5
1.You can check number 5 of this post to check break points:
2.You can use Node edit.
3.You can select Close Path, Close selected paths with tolerance, sometimes Auto.join selected shapes.
You can also search the docs for more info
