Co2 laser doesn't have enough power
I’m not arguing implementation. I’m arguing the reading of the listed specification.
I’m not aware of anything at a configuration level that would allow for selection of 3.3V vs 5V. Maybe a toggle on the board itself.
However, the fact that 50% reads at 1.7V makes me think this is intentional instead of degraded 5V signal. I suppose the level translator chip could have failed.
I suspect it’s not actually directly adjusting voltage down. I think the single potentiometer is just adjusting relative current. So by increasing current across the board you effectively compress the voltage required to reach the same currents.
Here’s what they have to say:
Link to what I’m reading from:
reci_dy10_dy13_dy20.pdf (ehlab.uk)
Yes you can’t trust them… You have to apply what you know about these to be true at time…
I had a grbl for the Arduino and it ran a 1mS period (1kHz)
The Ruida defaults to 50uS period (20kHz)…
I’ve run the Ruida at 1mS… jumping around to 16uS (60kHz), can’t tell the difference…
There’s also a major language issue…
What does this mean?
the pulse peak is required to reach 5V
I think it means, 5V to get the peak pulse… right to left…
They have to work similar for there to be any interchangeability… Sometimes I think it’s translated incorrectly or whatever… probably why there is so much debate over what it means. We see the same with Ruida manuals… Every time I see Wind on the Ruida, I think of passing gas :face_with_spiral_eyes: I guess that is an air assist.
I think the dlc32 is used a lot and mine was also 5V on the ttl output. Even reading the manual, it doesn’t say why you would need to adjust the lps… they promised a schematic, but I could never find it… I’d love to see it… even if Chinese…
I was thinking there may be more specific information about configuration of the pwm signal on the SD card.
I don’t think probing J7 will do much. It’s an open source mosfet… the other pin is 12/24V…
This might mean that 5V is required for this to work correctly, meaning TTL.
you say your dlc32 has 5V at ttl output?Is It possible that my dlc32 is broken?
That’s always a possibility… However the symptoms are odd to me.
I will dig mine out and try to re-flash the firmware and check it, but I’m sure it’s a 5V pwm… The computer on the controller is 3.3V, this output goes to a level converter that comes out as 5V wired directly to the J18 connector… It seems like a very odd type of failure.
I checked the wiring manual of dlc32 and It said “TTL input is PWM, the default main frequency is 1K Hz, 1K Hz~10K Hz can be set, and the voltage is
between 0V~5V” according to this maybe my board is broken
this is my grbl setting
Can you run this command in Console and return output?
$0=10
$1=25
$2=3
$3=4
$4=0
$5=1
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=0
$23=6
$24=300.000
$25=1000.000
$26=250.000
$27=1.000
$28=1000.000
$30=1000.000
$31=0.000
$32=1
$50=0
$38=0
$40=1
$100=160.000
$101=160.000
$102=80.000
$103=100.000
$104=100.000
$105=100.000
$110=10000.000
$111=10000.000
$112=6000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=500.000
$121=500.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=1300.000
$131=1850.000
$132=50.000
$133=300.000
$134=300.000
$135=300.000
ok
here you are
I was speculating that you potentially were viewing cached values in Machine Settings but that doesn’t appear to be the case.
Can you create a simple design and set the Cut layer power to 100%, then go to File->Save gcode, save with .txt extension and then upload that file here?
New Text Document (2).txt (4.7 KB)
here you are
This is interesting:
G1 X-1.843Y1.504S2666F1800
Have you changed the “S Value Max” setting? These values are incorrect.
New Text Document (2).txt (5.0 KB)
check this please
That looks correct now. Can you measure PWM voltages based on this?
I measured that It is still 3.22V
Okay… So now for sure the controller is being commanded to send 100% power but you’re still getting 3.22V. So either a faulty board or something we’re missing.
Honestly though, if you’re able to get linear voltage from 0V to 3.22V you probably wouldn’t have any issue adjusting the potentiometer to get you the range you need.
That would be an easy fix, as I stated before…
I think the problem should be fixed if possible, not apply a band aid that could fail at any time.
I adjusted the potentiometer and set it on about 3V,at 100% of power the current of co2 tube reached to 30MA
I’d like to point out that running 100% power when trying to get something to work is not necessary and not a smart approach.
The maximum suggested current for a RECI T4 is 26mA and you have exceeded that at 30mA.
It is much more wise to check current at 50% power (pwm) and check for 50% current. Pushing full power, is not a good idea. This is especially true when you are setting up the machine.
You have set this to a higher current at 100% than recommended by the manufacturer.
Glad you are up… whatever the process…
Good luck and have fun
