You need to advise about what lens you’re using. I have material libraries for each of my lenses. Not all have been used.
I have to set it every time.
I assume you mean both the fiber and regular visible light diode. Simply, no, the files are streamed to the machine where it executes the code. So your usb is actively sending to the machine.
You can make another instantiation of Lightburn and do what you are asking.
I have these that I use with my 60W, they came from Laser Everything, so if these don’t work for you check out theirs. This is for my F160mm lens.
160mm-fiber.clb (92.7 KB)
It’s much more convenient to most of us to use mm/s. Most galvos seem to top out around 10,000/S.
15000mm/m is only 250mm/s, so most of us have to figure it out… If you’re more comfortable with mm/m then so be it… it could add to confusion.
Check out these, maybe they will help…
Don’t forget to update your profile to show the addition of your fiber.
Have fun.
