I have an Ortur LU3-20A and searched for a material test to color engrave stainless steel.
I found these on an Ortur YouTube comment,
https://www.youtube.com/redirect?event=comments&redir_token=QUFFLUhqbmZSNnA5ZVl2Q1hkc09MLXJyLS1yXzVpMEl4UXxBQ3Jtc0ttN2hNUmZlcVdfQmxMOUtqRERuNWFrN3FGV3RPT1pZc1JDTjZEM3BTU0xUWEhndnV1STZ4X0FJbl9XbWJWbHZqOUd3VkJLOEdVWUN0RzBGNVJUZkY5NEJqZW5rOGFYaEd4bERjMGZ6WFR5V3VZR1A5aw&q=https%3A%2F%2Fcdn.shopify.com%2Fs%2Ffiles%2F1%2F0503%2F4734%2F4056%2Ffiles%2F20W.zip%3Fv%3D1693280308
I tried to copy the actual photos of the downloaded files but donāt know how to do that.
Can anyone please these files (settings) actually work?
Iāve looked at these settings and am completely confused.
Iāll be 80 years old in 3 weeks but yet still teachable,in small doses.
Thanks,
Tom
Try this file.
ThaTool_24W-Stainless Steel Color interval test speed3000.lbrn (266.4 KB)
parsec
I tried the file you suggected and it didnāt even mark the ss steel at all.
I ran other tests using a 1" square just to save time.I ran it as slow as 10 ipm/100 constant power and still didnāt mark the ss steel at all.
When I downloaded the file you suggested I got a pop-up window saying that the lightburn version you used was 7. something and that the file might not work with my version (1.6.06) This may have something to do with the file not working?
Also,In the file I showed (above) I saw that there were some values changed and or added in the console.Maybe this has something to do with it not even making a ,ark on the ss steel?
I have to change values in the console as I donāt know how to remove them if something goes wrong.
So,Iām completely lost right now.
Thanks for the suggested file.
Tom
With laser connected to correct com port type $$ in console and copy/paste the entire result here and also copy it to a .txt file, these are your GRBL definitions.
$120 and $121 are the accelerations of the axes.
When you say copy the console copy to a .txt file do you mean to copy it to something like Notepad?
Waiting for connectionā¦
[MSG:25:Info: USB SERIAL STREAM CONNECTED]
Ortur Laser Master 3 Ready!
OLF:211.
OLH:OLM_ESP_PRO_V2.4B.
OLM:GENERAL.
GrblHAL 1.1f [ā$ā or ā$HELPā for help]
ok
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[MODEL:Ortur Laser Master 3]
[OLF:211]
[OLH:OLM_ESP_PRO_V2.4B]
[OLM:GENERAL]
[DATE:20230417]
[SN:B9C44F7CF509B9ADA91485B17CF50A45]
[VER:1.1f.20220325:]
[OPT:VNZHS+,63,32767,3,0]
Target buffer size found
[NEWOPT:ENUMS,RT+,HOME,NOPROBE,TC,SED,UD,CLU,WIFI,FTP,TMC=7,SD,ITG,GT,YRR]
[FIRMWARE:grblHAL]
[NVS STORAGE:*FLASH]
[DRIVER:ESP32-S2]
[DRIVER VERSION:220327]
[DRIVER OPTIONS:GIT-NOTFOUND]
[BOARD:Ortur Laser Master 3]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[WIFI MAC:70:04:1D:FB:2C:1A]
[IP:192.168.5.1]
[PLUGIN:Power Detecter v1.0]
[PLUGIN:Power Control v1.0]
[PLUGIN:gyroscope sensor v1.0]
[PLUGIN:Trinamic v0.09]
[PLUGIN:SDCARD v1.05]
[PLUGIN:ITG STREAM v1.00]
[PLUGIN:ESP32 WebUI v0.03]
[PLUGIN:GADGET v1.00]
[PLUGIN:YRR v1.00]
ok
Homing
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:23900,16|Ov:100,100,100|A:SFM|H:1,7>
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0|VA:23872,11|A:SFM>
ok
Project loaded in 18 milliseconds
$0=5.0
$1=100
$2=0
$3=1
$4=7
$5=0
$7=0
$10=2047
$11=0.050
$12=0.002
$13=0
$14=0
$15=3
$16=1
$17=4
$18=0
$20=1
$21=0
$22=1
$23=7
$24=600.0
$25=800.0
$26=100
$27=1.000
$28=0.100
$29=0.0
$30=1000.000
$31=0.000
$32=1
$33=2000.0
$34=0.0
$35=0.0
$36=100.0
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=0
$46=0
$56=1.0
$57=1800.0
$58=395.0
$59=6000.0
$60=0
$61=1
$62=0
$63=3
$64=0
$70=31
$73=3
$74=Tenda_0A6450
$75=
$76=OLM3_AP_2C1A
$77=12345678
$100=100.000
$101=100.000
$102=100.000
$110=20040.000
$111=20040.000
$112=600.000
$120=2000.000
$121=1800.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$140=600
$141=1000
$142=800
$150=16
$151=16
$152=16
$160=0.000
$161=0.000
$162=0.000
$180=20040.000
$181=14028.000
$182=600.000
$200=65.0
$201=50.0
$202=60.0
$210=100
$211=100
$212=100
$220=50.0
$221=60.0
$222=60.0
$270=115200
$271=115200
$272=115200
$300=OLM3_STA_2C1A
$301=1
$302=192.168.5.1
$303=192.168.5.1
$304=255.255.255.0
$305=23
$306=80
$307=81
$308=21
$310=OLM3_AP_2C1A
$312=192.168.5.1
$313=192.168.5.1
$314=255.255.255.0
$330=admin
$331=user
$332=255
$339=3
$341=0
$342=30.0
$343=30.0
$344=180.0
$345=200.0
$384=0
$392=5.0
$393=3.0
$600=0
$601=5
$602=0
$603=5.0
$604=6.0
$605=1
$606=1
$607=0
$608=1
$609=1.000
$610=0
$611=0
$612=1
$613=14407
$614=0
$616=0
$617=0
$622=111
ok
Sorry, Iāve been very busy
Yes, it can be Notepad, itās just to keep a backup of your controller settings.
Ok, I have a test file according to the photos.
Download Ortur_stainless_color.lbmt.txt (1.2 KB)
This job lasts more than 3 hours(in my machine)
After download you have to remove .txt and get
On Lightburn console type :
- $120=500 enter
- $121=500 enter
Go to Lightburn Laser Tools , and select Material Test and then select the icon to Import preset(s)
Open the downloaded file Ortur_stainless_color.lbmt
Select Ortur_stainless_Color
Click Edit Material Setting and check your Layer settings
Do a preview and check Estimated time
Click start
After job ends
Revert settings back, on Lightburn console type :
- $120=2000 enter
- $121=1800 enter
Before you may try this file with only 2 columns
Stainless Steel Collor interval test speed900.lbrn (179.1 KB)
Thank you so much again.
Iāve been sick for the past 3 days but Iām āsemiā back now.
I will try to do what you have told me.
Wish me a lot of luck.
Tom
I ras 2 tests.One was very short,20 minuets and not a mark on the metal
I ran a second test of the entire file but made the squares smaller to shorten the total time.I ran that only 1 pass as I didnāt see anymarkings onthe metal.
ok
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[OLF:211]
[OLM:GENERAL]
[DATE:20230417]
[FIRMWARE:grblHAL]
[DRIVER:ESP32-S2]
[TYPE:OLM3]
[CLUSTER:16]
Cluster size found
[IP:192.168.5.1]
[PLUGIN:YRR v1.00]
ok
Homing
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:23921,13|H:1,7>
OLF:211.
OLM:GENERAL.
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0|VA:23900,16|Ov:100,100,100|A:SFM>
ok
$0=5.0
$1=100
$2=0
$3=1
$4=7
$5=0
$7=0
$10=2047
$11=0.050
$12=0.002
$13=0
$14=0
$15=3
$16=1
$17=4
$18=0
$20=1
$21=0
$22=1
$23=7
$24=600.0
$25=800.0
$26=100
$27=1.000
$28=0.100
$29=0.0
$30=1000.000
$31=0.000
$32=1
$33=2000.0
$34=0.0
$35=0.0
$36=100.0
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=0
$46=0
$56=1.0
$57=1800.0
$58=395.0
$59=6000.0
$60=0
$61=1
$62=0
$63=3
$64=0
$70=31
$73=3
$74=Tenda_0A6450
$75=
$76=OLM3_AP_2C1A
$77=12345678
$100=100.000
$101=100.000
$102=100.000
$110=20040.000
$111=20040.000
$112=600.000
$120=500.000
$121=500.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$140=600
$141=1000
$142=800
$150=16
$151=16
$152=16
$160=0.000
$161=0.000
$162=0.000
$180=20040.000
$181=14028.000
$182=600.000
$200=65.0
$201=50.0
$202=60.0
$210=100
$211=100
$212=100
$220=50.0
$221=60.0
$222=60.0
$270=115200
$271=115200
$272=115200
$300=OLM3_STA_2C1A
$301=1
$302=192.168.5.1
$303=192.168.5.1
$304=255.255.255.0
$305=23
$306=80
$307=81
$308=21
$310=OLM3_AP_2C1A
$312=192.168.5.1
$313=192.168.5.1
$314=255.255.255.0
$330=admin
$331=user
$332=255
$339=3
$341=0
$342=30.0
$343=30.0
$344=180.0
$345=200.0
$384=0
$392=5.0
$393=3.0
$600=0
$601=5
$602=0
$603=5.0
$604=6.0
$605=1
$606=1
$607=0
$608=1
$609=1.000
$610=0
$611=0
$612=1
$613=14407
$614=0
$616=0
$617=0
$622=111
ok
<Idle|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:23914,19|H:1,7>
ok
Starting stream
Stream completed in 0:22
<Idle|MPos:185.660,164.770,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:23914,133|A:SFM>
ok
[GC:G0 G54 G17 G20 G90 G94 G49 G98 G50 M5 M9 T0 F550 S20.]
Starting stream
Stream completed in 0:21
Starting stream
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Stream completed in 34:01
<Idle|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|WCO:0.000,0.000,0.000|VA:23977,13|A:SFM>
ok
[GC:G1 G54 G17 G20 G90 G94 G49 G98 G50 M5 M9 T0 F2999 S0.]
Starting stream
Stream completed in 0:04
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
OLF:211.
OLM:GENERAL.
[MSG:ā$Hā|ā$Xā to unlock]
error:9
G-code locked out during alarm or jog state.
[MSG:3:Warning: Caution: Unlocked]
ok
OLF:211.
OLM:GENERAL.
<Home|MPos:308.340,264.770,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:23970,10|Ov:100,100,100|A:SFM>
[GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.]
<Home|MPos:0.000,0.000,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0|VA:23970,23|A:SFM>
<Home|MPos:-39.820,-39.820,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-79.830,-79.830,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-119.850,-119.850,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-159.860,-159.860,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-199.870,-199.870,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-239.890,-239.890,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-279.890,-279.890,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-319.880,-319.880,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
<Home|MPos:-359.870,-359.870,0.000|Bf:63,32767|FS:1131,0|CL:0,0|PS:2,0>
ok
Project loaded in 12 milliseconds
<Idle|MPos:0.000,0.000,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:23963,15|H:1,7>
ok
Starting stream
Stream completed in 0:23
<Idle|MPos:177.280,172.020,0.000|Bf:63,32767|FS:0,0|CL:0,0|PS:2,0|VA:23928,152|A:SFM>
ok
Starting stream
Stream completed in 0:28
Starting stream
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Layer
Job halted
Stream completed in 1:29:20
ok
ok
ALARM:3
ok
OLF:211.
OLM:GENERAL.
error:9
ok
I ran 2 more tests today.
First was with values 120 and 121 changes as suggested.
Speed 300 amn1000 at 100% power on 1/4" squares set on fill.
Second test was with values 120 and 121 set back to original settings.
Neither test even showed the slightest markings onthe stainless steel.
I ran 1 more test at 10 inches/min at 100% power on a 1/8" square set on fill.Still nothing.
I took the laser module off and this is what I found,
Even the air assist port was clogged.
I cleaned everything and quit for today.
I hope to try again tomorrow.
I hope you`re feeling better.
Is the air-assist malfunctioning?
Is the air pump near the laser? Sucking air with dust?
Are you using 304 stainless steel?
Feeling much better,thanks.
Yes the air assist is near to the engraver but I havenāt done much engraving at all with this new machine as I spemd most of my time in my small/hobby woodshop.
The stainless may be either 308,304 or even 316. I suspect itās either 308 or 304 though. My sone used to have a sheet metal shop in my basement and I saved all of the scrap pieces of ss so I donāt know what type it is that Iām using here.
Thank you for you intreest and help,
Tom
What about the thickness of the stainless steel? Try <2mm. I forgot to ask in the previous post.
Why is the module so dirty?
Is there air coming out of the air-assist port? If you need to clean the air pump, check at the end of this link.
Iāve seen some Ortur videos, it looks easy, but I donāt know if any settings are missing, it looks like weāve checked everything (Myself, on a different machine, donāt get all the colors as they say).
Do you often get these GRBL errors? ( ALARM:3 error:9 )
These 2 two squares, at least, should make a dark engrave
_SS_2_squares.lbrn2 (35.2 KB)
I have a fiber and Iāve found that the color process varies in a wider range varying the interval.
Youāre heating this up, not melting or burning anything, so I doubt youād need air assist and that may be detrimental to the process. The debris on the laser module doesnāt look like any kind of metallic debris, looks organic.
This is a stainless dog tag, Iām varying speed and interval.
The type of metal makes a lot of difference, along with thickness, especially with lower wattage machines and visible light.
You might do better with Titanium, it produces a wider color range. If you have random types of metal around and donāt know what they are, your color response will change with a change in the materialā¦
Change in metal type, change in settings⦠Sometimes you change the size of the area, the color changesā¦
Good luck
[quote=āparsec, post:13, topic:136320, full:trueā]
Is there air coming out of the air-assist port? If you need to clean the air pump, check at the end of this link .
[/quote What about the thickness of the stainless steel? Try <2mm. I forgot to ask in the previous post.
_SS_2_squares.lbrn2 (35.2 KB)]
I am using material that is almost .0125" thick and that looks like a huge problem.I will find much thinner material.
I believe the moduel got that dirty when I first ran it trying to engave deep enough for a 2" x 4" engraving. I now know that I shouldnāt have done that and have cleaned the lens and everything that was dirty.
I just sent an email to Ortur support asking how to clean the air port (s) inside of the moduel.The pump is working fine and I have aiir through the hose but not at the laser tip.
I donāt know anything about the alarms or even how and or where to find them? I assume they show up in the console but when?
I will download the 2 squares you sent and give it a try.
Something that I donāt like is that when you have the material test page open,there is no way to home the machine unless you close out the material test page. I always home the machine before I start a project so this is a problem for me,and maybe others too?
Thank you again,
Tom
I just ran txhe test with 2 squares and finally got some results!
Then I ran this test and got even better results,
I am certain that this ss is 316 and itās much thinner then the other pieces I did tests on.
The test buckled the metal quite a bit but I guess thatās expected?
My problem I that I donāt know how to āreadā this material test to duplicate the row with the 7 colors?Can you please help me with this?
Thanks ever so much for sticking with a senior man who is in way over his head with all of this. You guys are fantastic teachers!
Age is just a number, nowadays we donāt get older, we just gain more experience. And we learn from each other. What is the meaning of life?
Back to the point:
Finally we have color.
We are using the laser to heat the stainless steel (so with a lot of thickness and with our weak diode lasers it doesnāt work, the metal dissipates the heat supplied), by varying certain parameters that we more or less control (power, speed, interval), films of colored or colorless oxides are formed on the surface.
Itās normal for the material to deform, weāre creating tensions at various points.
In the test do not need to change the power, we are not burning at 100% and after it is not a direct read (let`s say you want a burn with your 45% settings, as you changed to 95% power in Cuts/layers in reality what produced your 45% was (45x95/100=42.5%power), so keep the 100% value).
Example: You`ll want to fill a shape with the marked color
- Select the layer of your shape
- Edit layer settings
- Select fill, constant power mode and input 400mm/m 40% power and 0.02 line interval
. And you would get more or less the same colorā¦
With a similar piece of stainless steel I would try again the 3000mm/m file because if we reduce speed the job takes more time
Ortur_LU3_20A_SS_Color_interval_test_3000mm-m.lbrn (721.5 KB)
Ortur_LU3_20A_SS_Color_interval_test_900mm-m.lbrn2 (366.1 KB)
Ortur_LU3_20A_SS_Color_interval_test_600mm-m.lbrn2 (389.6 KB)
The above files have 3 tests with 2 more power columns each (1 full and 2 split jobs)
For me this is more or less an English exercise, I hope I`ve explained well or at least you could understand what I mean to. ![]()
You explained it very well but Iām a little confused.
How do you know to run at 400mm/min
Iām confused with the power settings.
Some places where we can change settings on Lightburn.
Some places where we can select layer and then change speed
Iād recommend reading the LightBurn Documentation though, lots of useful information there with a section for beginners,
thank you again,
I know how to do all of the above you posted,how to change speeds and percentage of power.
What I am asking is how did you know to set the machine at 400mm/min?
On this material test I can see that the āblueā layer is layer 0.02ā¦
But on the very top of the test it says,
Machine:Tha Tool 23 W
Power:100% Speed 3000mm/MIN
I can see on the bottom that the power on layer 2 is at 40%,this I understand but the speed you suggested is 400mm/min and I donāt understand how you came to that result when On the top it says 3000mm/min?
Also,Some time ago you told me to change values
$120=500
$121=500
I changed them back to the original values of:
$120=2000
$121=1800
I ran the last 3 tests with the normal values and not the edited values yet Iām getting pretty good results.
Would I get better results if I change those values to the edited values,
$120=500
$121=500
Iām sorry for bothering you with all of these basic questions and I thank you for taking interest in me and my old brain.
Tom
