Color palette isn't visible on my laptop
When I use Lightburn on my laptop, I can’t display the color palette as a window. It’s possible to do this on my PC without any problems. What can I do?
Thank you!
There should be a faint corrugated grab handle on the very left end of the palette:
Grabbing that should disconnect the palette from the bottom of the display and let you haul it where you want it.
However, if the problem is the palette has vanished, then:
  • Set the Windows Task Bar to Auto-Hide, which will provide a few more vertical pixels
  • Maximize the LightBurn window to use the the whole screen
  • Make sure the palette is enabled in the LightBurn Windows list
If you just installed LB 2.0 on a shiny new laptop with a high-res screen and Windows HDPI scaling in full effect, then:
If none of that helps, more information on the laptop and a screenshot will help us see what you’re (not) seeing.
Thank you very much for your helpful answer.
The problem was the palette has vanished, then:
I set the windows task bar to Auto-Hide - my problem has been solved.
