Good day! Where can I find and download config file for Lightburn 1.4.04 for CR-Falcon 10W. Thank You!!!
Hi. It is on the Micro CD card you got together with your machine. If I remember it is under …/software/lightburn
As Deon said.
I saved the content of the key to my hard disk, just in case.
So it is in 2. Software > LightBurn > CR-Laser Falcon.lbdev
Is it downloadable from the Creality site somewhere? I cannot find my microcard.
If I remember correctly, I saw it on Creality’s Redit site.
I give it there: New user need help - #5 by _steve
Otherwise, it might be in the official support files: CR-Laser Falcon Laser Engraver Software& Firmware Download - Creality 3D
I also found, though I might be mistaken, that in addition to doing those things, I pressed in the round circular LED button and held it in until it gave one long beep and two short beeps. AFTER I did that, the connection was made. I suppose it might have been something else I did, but it seems to me that it made the difference which worked.
(I had turned on the 10W, plugged in the USB cable, imported the .lbdev file, and even rebooted everything, but the laser did not respond to any commands, even though the indicator said “ready.” But after I depressed and held that button, things worked as expected – and have been ever since.)
Thank you for your help.
