Connecting to laser and camera
I only have one USB port on the laptop I am using to run Lightburn and the laser. I bought a USB hub and connected both with that. The first time it worked Ok and I got the camera calibrated, aligned, and tested its use. Now when I try to use it the laser won’t connect unless it is connected to the USB port of the laptop. Thus I can’t use the camera. This is a mystery since it did work at one point. Anyone any suggestions as to what to try?
This is likely to be hit or miss. Not all USB hubs are of equal quality. At a minimum I’d suggest trying a powered USB3 hub.
Ok thanks. I will try that.
Using a powered hub did the trick. Thanks for the help.
