Connection lost on long burns with Snapmaker v2.0 A350 on Lightburn v0.9.20
Hi I keep having disconnection issues with my Snapmaker v2.0 A350. It has only recently started which prompted me to turn off all power saving options for the USB’s as per a thread I found on this forum. I am yet to buy a licence and have about 3 days of trial left however thus far with the issues experienced I have not really managed to trial the software to its full extent with my Snapmaker. I attempted to laser a picture on cork last night and lost connection 4x + prompting me to restart every time midway through resulting in a much darker image than I was after. I have included some information from the console. I lost connection midway through C27 meaning I had to redo part of C27 resulting in an undesired effect. I have tried generating the gcode and using a usb plugged into my snapmaker to eliminate this connection issue but it results in the image being etched in some random location so not sure why the gcode differs in that respect. I am fairly new to this so any info or advice would be much appreciated.
Starting stream
Stream completed in 0:00
door opened!
door closed!
Starting stream
Starting stream
echo:busy: processing
Stream completed in 0:07
Starting stream
Layer C00
Layer C01
Layer C02
Layer C03
Layer C04
Layer C05
Layer C06
Layer C07
Layer C08
Layer C09
Layer C10
Layer C11
Layer C12
Layer C13
Layer C14
Layer C17
Layer C18
Layer C19
Layer C20
Layer C21
Layer C22
Layer C23
Layer C24
Layer C25
Layer C26
Layer C27
Connection lost
Stream completed in 32:40
��ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
door opened!
door closed!
Starting stream
Starting stream
Layer C27
Layer C28
Layer C29
Stream completed in 3:15
As an update, I have rolled back the version of Lightburn to v0.9.19 and have thus far been burning for approximately 40 minutes with no disconnection. Might be something that has changed in the gcode compiler between v0.9.20 and v0.9.19? Will update this post once the burn has completed but so far it seems to be working as it should.
