I just haven’t took the time to figure it out. I read you run the cable to your router and my laser setup is in the basement.
Much easier.
Get a cable. plug it into both machines. Configure the RuiDa with 10.10.1.100, 255.255.255.0
Configure the PC ethernet with 10.10.1.1, 255…255.255.0 - no gateway needed on the PC - it already got that from the WiFi and has set up the routing tables for you.
Go to cmd, type ‘ping 10.10.1.100’ and see if you get a return.
Never use USB again
Awesome. I’ll give this a shot first then. My laser came with a short Ethernet cable.
Looks like it’s working with Ethernet! Thanks again.
No worries. Glad it is sorted.
I’ll note I’ve had issues with this on USB when switching between my vinyl cutter and laser cutter on the same laptop.
Will switch to Ethernet and hope to fix that challenge.
