Connectivity issues
It’s quite possible that your network itself is using the same address for something else and causing issues - setting that address as reserved in your router can fix it, or just making sure the laser is using a value that’s far enough away from where your router reserves IDs works too.
Read through this and see if it helps: How do I connect a Ruida controller with Ethernet?
