How do I connect a Ruida controller with Ethernet?
Setting up a Ruida controller to connect via Ethernet isn’t hard, but it’s not quite as simple as just plugging it in. Follow these steps:
1) Get the IP Address of your computer:
For Windows:
Open a command prompt (click the Start button, type CMD, and hit enter).
Type IPCONFIG and press enter.
You’ll see something like this:
The one labeled ‘IPv4 Address’ is the interesting part - this is the network address of your computer on your local network. The first 3 groups of numbers will be the same for every device connected to your network, and the last number (the ‘14’ in my picture) will be different, and MUST be different, for each device. They all need a unique address so they don’t try talking over each other.
For Mac:
Open a terminal window (Command+Space, then type terminal). At the command prompt, type ifconfig and press enter. Near the beginning of the output, you should see something like:
en0: flags=8863<UP,BROADCAST, ...> mtu 1500
      ether 4c:c2:xx:xx:xx:85:xx
      inet6 fe80::2431::xxxx:xxxx ....
      inet 192.168.1.102
The line that starts with inet is the interesting one - That’s the IP address of your computer on your local network. You might have more than one network - en0 is the first, en1 is the second, and so on. One will be active, so use the inet address from that one.
2) Assign an address to the controller:
The next step is to assign an address to your Ruida controller that is different than the other devices on your network, but has the same first 3 numbers. The range of each of the numbers is 1 to 255. I recommend using a different chunk of the network space for your lasers so they don’t interfere with other things. To do this, pick a different set of ‘hundreds’ from where your PC is.
If your PC address is:         Set your laser to:
10.10.1.154                    10.10.1.54      (subtracted 100)
192.168.2.201                  192.168.2.101   (subtracted 100)
10.100.50.14                   10.100.50.114   (added 100)
You don’t absolutely have to do it this way, but putting the laser ‘100’ away from your PC reduces the chance that a new device connecting to your network will be given the same network address as your laser. There are ways to tell your home router that an ID is reserved, but that’s beyond the scope of this post.
Once you’ve picked a network address for the laser, you have to tell the controller what it is. On the Ruida controller, press the ‘Z/U’ button to enter the menus. Use the up/down arrows to move to 'IP Config+" and press the Enter button. You’ll see this display:
Use the arrows to change the values and move the cursor, and press Z/U to move from one value to the next. When done, press the Enter button.
3) Create a networked device profile in LightBurn
Now, in LightBurn, you need to manually create a controller profile with the IP address you’ve chosen. Click the ‘Devices’ button:
Then click ‘Create Manually’:
Choose ‘Ruida’ from the controller list, then choose Ethernet, and enter the same IP address you used on the controller itself. Set a name for the laser, and enter the bed area in mm (mine, for example, is 700 x 500 mm). Set the origin corner to the corner where your laser homes. When you’ve done all this, you’ll get a summary page to review, like this:
Click ‘Finish’, then you can make that laser the default device if you like, and click Ok to exit the device setup screen. If you made the new laser the default device, it should connect right away, otherwise you might have to choose it from the devices list.
Ethernet connection not working on 60 WATT
LightBurn not finding my laser
Connecting to Ruida
Accessing LB via my network
Apple mac ruida and vonets300
Connecting via network
My computer cant connect to RDC6445G controller
Help with Mac issues
Setting up network and im pretty new to networking
Ethernet Not Connecting
Mac doesn't connect to Ruida, using USB c
Mac Networking yet again
Every thing is mirrored
Lightburn not recognizing laser
Lightburn will not connect now
Connectivity issues
Mac cannot find my laser
LightBurn does not detect Ruida 6442S-B
Back with the Same Issue... Lightburn on Mac Cannot Find Laser
Ruida network connection
How to connect Laser to Computer
Problems downloading and running Lightburn on Catalina 10.15.6
Lightburn doesn't connect to BOSS LS 1630
Laser not connecting
Hallo ich bin Kurt
Laser goes out of whack
MacBook Pro Lightburn not connecting RUIDA RDC6442S-B
Random Cutting Issues
Running 2 boss ls2440 laser machines. Can this be done with one computer and 2 usb cables, or do you need seperate computers?
The laser does not appear to be considered connected
Data Transfer Failed after update
Will not comunicate to laser
Rudia Koenig Machine not connecting with ethernet
Can't connect to RUIDA 6442S via USB on Macbook Air M1 Mac Os X 11.4 (big Sur)
Lightburn won't connect to OM Tech 60 w laser
Need Help Installing FDTI Serial Drivers
Light burn does not connect to laser
Lightburn not seeing USB
::Sigh:: Not connecting
Help with apple
Unable to send file to Ruida controller
Issues with lightburn / MacOS / Ruida
Connection problems
Files sent to laser, but no response from machine
New Mac with light burn not picking up laser
Mac and Update Issues
Lightburn says laser is disconnected
Can anyone explain why one MacBook air connects easily and another only connects after a restart?
I can't get my computer to recognise my laser
Just Installed New Version of Lightburn LightBurn.V1.0.02
Keep losing drivers
Rdworks won't connect but LB will
Please Help! Cormak 6090Z RDC6442G
Ruida control disconnected
RD Controller had been replaced and I cannot connect via WiFi
LightBurn can’t find laser after Ethernet setup
Connecting to laser USB but saying disconnected
Communication With Controller Failed Error
Back with the same problem...LightBurn cannot find COM3,
How do I connect a Ruida Controller with Ethernet? (cont)
Cannot get LB to recognize OMTech 60 on Mac
Desktop not talking to laser through Ethernet cable
LightBurn running on MacBook Air M2 cannot find AP Lazer 2816
No ethernet connection, MAC OS Sonoma & rudia controller
How do I run two lasers at the same time
(Update: Problem Solved) Laptop Won't Connect
A tip for setting up ethernet connection
Unable to network laser through direct ethernet connection to Ruida 6445 from macOS
Only Framing half way and then stops
Boss LS1416 Can not get it to communicate to my laser. Using a MAC
New 40ft USB cable and now “laser is busy”
There was a problem sending data to the laser
My MAC no longer sees my Laser
Crash on initial device scan under OSX Catalina
Connecting Ethernet with a Crosswired Cable
Lightburn with Rudia RDC6445G(EC)
Lightburn won't recognize my machine anymore
Help: Lightburn not recognizing my red and black chinese laser w ruida on Mac OS
Lightburn will not connect to ruida controller
Mac Not seeing laser
Lightburn does not detect RUIDA 6442G-B controller
MacBook Pro New Model Not Connecting to my Laser
Not sure what controller my machine has
Device displays “Disconnected” in laser control panel
Ruida to Mac Via Ethernet with Adapter
New Laser user on a Mac
Setting up on Mac
Randomly missing lines when uploading file to laser
Lightburn application crashes during Device Discovery Wizzard
