I have followed the steps for ethernet connection on my Mac computer. I have the IP address set up the same, all up to the last 3 numbers being 76 &176. as detailed in forum below:
Lightburn shows the laser was found but it still shows as disconnected. I removed it and started again with no luck. I have spent hours trying to solve the driver issue but can’t find an exact forum for my version of Mac. Please Please Please someone guide me in the right direction.
I think this works on a Mac from the terminal… it should list all of the devices on the local network. Just got this Mac, so I’m not used to it. If you have something that will show what’s on your lan that’s what you need.
Sometimes the browser router interface will allow you to see what is on your local network.
You can pick up a wireless router pretty cheap… I ran mine in the garage via a $12 wireless T-link router from Amazon. It’s just setup as a bridge and the laser plugs into it…
I am not as technologically inclined so I’ve had to google a few things to have hopefully gathered all you are asking for. I used LightBurn on this Mac with my diode for years and now this transition to Rudia has my extremely frustrated.
Can you show your network settings for the wifi connection?
The ping command failed. Can you confirm the Ruida was turned on during this and that the ethernet cable is connected? Check to see if you are getting lights on from the ethernet adapter on your computer. There should be two LEDs. Are they blinking?
Yes it was on. The Ethernet connection to my computer comes from the ethernet prt on the laser then is a type c connection at the computer, my computer only has type c ports. Should I try a different type of cable adapter?
You should have 2 separate network connections, one for wifi and one for ethernet. Leave the wifi to automatic IPv4 configuration.
What you need is to manually configure the ethernet port. Can you show the network setup page that shows all your available connections?
Also, you should have the Ruida on a different subnet to avoid potential collision. I’d suggest switching back to the default 10.1.3.3 on the Ruida.
Finally, for that cable, is that the exact cable that you are using? I don’t believe that actually provides an ethernet adapter. It’s meant for limited serial communication on an RJ45 connector. Do you have a USB-C to ethernet adapter?
I do not have that adapter. I just ordered the one you are referring to, as soon as it comes in I will try it and make those other changes and follow up.
Thank you so much for your time, I’ll follow up in a few days when it comes in!
I have swapped the cables and changed the ip address to 10.1.3.3 on the controller. I ran the ping on that ip address with still no such luck. I manually configured the ethernet to that IP address. It is showing connected. still no changes in light burn
