I bought this Ortur Laser master 2 a 5 days ago and been using it pretty often. Since yesterday I am getting a constant connection issue where the machine stops and tells me that my USB is no longer connected. I already changed all the cables to new ones but still it keeps stopping after 2 minutes. Is there something else I can do to fix this?
2 things to check for:
- What’s the version of the firmware? If it’s very old Ortur has updated the firmware to address some connection issues. Latest version for Laser Master 2 is 1.42. Ortur – Firmware Repository – Ortur
- If you got an old stock item it’s possible that this machine has a ground issue. Can you review the material on this site Ortur – Ortur Laser Master Grounding – Ortur? Visually examine your unit to see if it already has the modifications to properly ground the machine. This was a well-known issue that Ortur addressed earlier this year but it’s possible you have an old stock item.
Based on your symptoms it sounds very much like the grounding issue I experienced with the unit but hard to say.
Important to get a full console log
The disconnects might be the result of a different error all toguthere
Could you maybe retry a engrave and if it locks, copy the FULL contents of console here please?
It stopped again and this is the only note it gives me “connection lost”.
Gonna apply that grounding hack they showed on the site and change the power cable. Hopefully that will work
Bjorn, is that the entire console contents? As in copying from the beginning to end? If not, might be helpful to Gil.
Did you confirm that your laser does not have any of the grounding components in place already?
Hello,
Just bought a Ortur Laser Master 2 S2 to try my hand at some laser engraving. It has been working great for the past week, but tonight, I keep losing connection in the middle of a carve.
I have checked my cables, my firmware is updated, and I have checked my ground.
Below is the full text from the console section. Very frustrating!
Waiting for connection…
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 S2]
[OLF: 190]
[OLH: OLM_ESP_PRO_V1.2]
[SN: F914C25E0A69DE134CDE5FBEC6F898AB]
[OLM:GENERAL]
[DATE:18:29:40 - Oct 18 2022]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,35,7680,3]
Target buffer size found
ok
Homing
ok
Project loaded in 24 milliseconds
<Idle|MPos:0.000,0.000,0.000|Bf:35,7679|FS:0,0|Pn:P|CL:0,100|PS:2,1|WCO:0.000,0.000,0.000|VA:23684,80|A:S|H:1,7>
[GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F6000 S0.]
ok
Starting stream
Stream completed in 0:02
<Idle|MPos:2.475,2.550,0.000|Bf:35,7679|FS:0,0|Pn:P|CL:0,100|PS:2,1|VA:23687,83|A:S>
[GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F6000 S20.]
ok
Starting stream
Stream completed in 0:05
<Idle|MPos:2.475,0.438,0.000|Bf:35,7679|FS:0,0|Pn:P|CL:0,100|PS:2,1|VA:23698,86|A:S>
ok
Starting stream
Stream completed in 0:08
<Idle|MPos:0.475,0.438,0.000|Bf:35,7679|FS:0,0|Pn:P|CL:0,100|PS:2,1|VA:23712,88|A:S>
[GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F4200 S20.]
ok
Starting stream
Stream completed in 0:10
<Idle|MPos:0.475,0.438,0.000|Bf:35,7679|FS:0,0|Pn:P|CL:0,100|PS:2,1|VA:23618,235|A:S>
ok
Starting stream
Stream completed in 0:13
ok
Starting stream
<Idle|MPos:0.475,0.438,0.000|Bf:35,7679|FS:0,0|Pn:P|CL:0,100|PS:2,1|VA:23656,232|Ov:100,100,150|A:S>
ok
Starting stream
Starting stream
Layer C00
[MSG:]
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 0:
Job halted
Stream completed in 43:06
[MSG:Reset to continue]
ok
Ortur Laser Master 2 S2 Ready!
OLF:OLF 190.
OLH:OLM_ESP_PRO_V1.2.
OLM:GENERAL.
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
ok
Starting stream
Layer C00
Connection lost
Stream completed in 59:11
[MSG:Power Supplied]
ok
ok
ok
ok
ok
ok
ok
ok
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[OLF: 190]
[OLM:GENERAL]
ok
Homing
ok
Starting stream
Layer C00
Connection lost
Stream completed in 25:46
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
G0
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
$I
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[OLF: 190]
[OLM:GENERAL]
ok
Homing
$H
ok
Alarn 2 sets when your design is wanting to send the laser past the bounds of your laser. Your design is either bigger than your work area or more likely you have it positioned incorrectly.
