Continue d'avancer une fois au point 0, positon -600,-600 sur lighburn
Bonjour,
Quand j’allume la ortur master 3, elle continue a avancer sur l’axe X et Y et finie pas se retrouver en position X=-600, Y=-600, j’ai fais une mise a jour firmware et rien ne change.
Elle fait donc un bruit bizarre quelle elle essaie de reculer au point 0 alors qu’lel y est, cela dure 2 min puis elle s’arrête et sur lightburn elle est position négative.
Quelqu’un a déjà eu se problème ?
Voici une video.
Good morning,
When I turn on the ortur master 3, it continues to advance on the X and Y axis and ends up in position X=-600, Y=-600, I did a firmware update and nothing changes .
So it makes a weird noise when it tries to go back to point 0 while it is there, it lasts 2 minutes then it stops and on lightburn it is in negative position.
Has anyone ever had this problem?
Here is a video.
Is it set to home when you turn it on? Does it have homing switches? What corner is it set to home in?
HI,
Yes, it set to home when I turn it on.
Does it have homing switches? → I don’t know what are homing switches .
What corner is it set to home in? → I don’t know
I have ortur master 3
When it tries to home what corner does it go to?
I goes to bottom and left
Try homing it and then go to console and typing in G10 L20 P1 X0 Y0 enter.
I have already the same error x=-600 and Y=600.
In the console I have error : Autoguidance failure. Cannot find search remote limit switch. Defined as 1.5* max_travel during search and 5* during locate phases.
