Continuing the discussion from Job Origin Discrepancy:
I erased original test file and made another from scratch. “Start from” set at “user origin.” “Job origin” dot set at bottom left as you face the 9-dot array. Before the crash, it would frame from upper left of square, going right, down, left, and up to start point. Now, the frame function is almost opposite. It starts at upper right corner of square and goes left, down, right, up, left and right back to start point. Doing a cut of the square is odd. with laser at same start point on the wood, it diagonals over to lower left, goes up, right, down, left, and diagonals back to start point. Again, “start from” is set at “user origin” and “job origin” is bottom left of the 9 possible dot locations. None of the different job origin positions seem to correspond to the frame/cut results.
