Coordinates do not show
HI there .
I did a post in the software section and was unsure if it needs to be in this section.
I have a Custom machine PrintNC using GRBLHal controller.
My issue is that it does not show the coordinates (M) (W).
I have tried many programs and l have tried Candle and Gsender IOsender, Openbuilds, and UGS.
The only ones i cant get to work is Millmage and Lightburn.
MY $10 value is 511
Any help would be appreciated.
Shane,
Double posting will not get you a faster answer, and it just spreads the replies out over 2 threads. This makes it difficult for someone with the same issue to locate a solution if one is posted.
Yes sorry . Wasnt trying to double post but thought because it looked more like a hardware issue maybe that it need to be this section.
That’s right, the Hardware Compatibility section is more appropriate in this case.
I appreciate the attempt to keep things organised.
You can change the category of an existing post by clicking on the pencil icon next to the title of the post.
I’ve moved the other thread now. Jon and I are monitoring closely.
