Copying/exporting cut settings across projects
Is there a way to share cut settings from one project to another, or to export and import just the cut settings? I notice that when you create a new project, it uses the settings from the currently open project. It would be really nice to be able to import export those easily, or to set settings globally that will be used for any new project, or to bring in your own favored settings to a project that was downloaded from somewhere else.
Use the material library?
Thank you! I had overlooked the material library.
You bet. We use this to create Template Files all the time.
