Having exactly the same issue here albeit with the Falcon 10W. Not showing up in terminal or LB regardless of anything suggested above. Happening on a MBP running Catalina.
Really hoping someone might find a workaround for this soon.
I don’t have a mac or that machine, but I have Linux and some of the commands might help.
“lsusb” will list what devices are ‘hanging’ off the usb ports.
jack@Kilo:~$ lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 056a:0011 Wacom Co., Ltd ET-0405A [Graphire2 (4x5)]
Bus 003 Device 002: ID 1af3:0001 Kingsis Peripherals ZOWIE Gaming mouse
Bus 003 Device 066: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
jack@Kilo:~$
This entry from lsusb if from my Chinese led laser and yours might be the same or very similar.
There is a file where system messages are logged. I plugged in my ‘dragon’ and here’s how it shows in the log file…
dmesg usually requires root privilege … it’s also very long … pipe it though ‘tail’ to only get the ‘tail’ end of it…
jack@Kilo:~$ sudo dmesg | tail
[1537511.362953] audit: type=1400 audit(1664892520.980:309): apparmor="DENIED" operation="capable" profile="snap.chromium.hook.configure" pid=2048438 comm="fc-cache" capability=2 capname="dac_read_search"
[1537511.362964] audit: type=1400 audit(1664892520.980:310): apparmor="DENIED" operation="capable" profile="snap.chromium.hook.configure" pid=2048438 comm="fc-cache" capability=1 capname="dac_override"
[1537519.686375] audit: type=1400 audit(1664892529.304:311): apparmor="DENIED" operation="capable" profile="snap.chromium.hook.configure" pid=2048438 comm="fc-cache" capability=2 capname="dac_read_search"
[1539020.890769] usb 3-2: USB disconnect, device number 64
[1539025.295774] usb 3-2: new full-speed USB device number 65 using xhci_hcd
[1539025.445229] usb 3-2: New USB device found, idVendor=03eb, idProduct=2107, bcdDevice= 1.00
[1539025.445243] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1539025.445248] usb 3-2: Product: AVRDRAGON
[1539025.445252] usb 3-2: Manufacturer: ATMEL
[1539025.445256] usb 3-2: SerialNumber: 00A200063403
jack@Kilo:~$
At least you should be able to ID the device and acertain if the OS is accepting it…
If the dmesg shows ‘disconnected’, it’s not talking properly…
I’ve been trying to use Lightburn with my new iMac and Atomstack a20, but I’ve had the same sort of problem that others have mentioned here.
I’ve run through the recommended actions, including buying a new cable. My iMac recognises the device, but I have had to input the device details manually. However, it remains ‘Disconnected’ in Lightburn’s Laser window.
Also - in the console window, I get the message:
Waiting for connection… Port failed to open - already in use?
How do I ensure the relevant port is open so Lightburn can function?
I’d be really grateful for help with this, as I’m new to this technology and it’s been a steep learning curve to even get to this stage.
Relevant info:
iMac specs: 24 inch, M1, 2021
MacOS Monterey 12.6
Atomstack a20 Pro
Mac System Report shows the Atomstack is on USB Serial
USB Serial:
Product ID: 0x7523
Vendor ID: 0x1a86
Version: 81.33
Speed: Up to 12 Mb/s
Location ID: 0x02400000 / 1
Current Available (mA): 500
Current Required (mA): 102
Extra Operating Current (mA): 0
Terminal response:
Last login: Tue Oct 4 17:18:29 on console
paulfretwell@Pauls-iMac ~ % ls /dev/usb
/dev/cu.usbserial-240 /dev/tty.usbserial-240
Thanks. Also tried this but I can’t even get the firmware to update (as far as I can tell). Laser goes into a repeating beep cycle that never ends. I’ve reached out to support but still no solution. Works fine offline, just annoyed I can’t get it to work with my Mac.
