Say you have a picture that would carve fine but you want to draw a box around the picture so that it carves outside the picture as well leaving the picture looking raised. Is that something can be done in millmage or have to be done with another app?
Yes - you would draw a rectangle around the part, then use that geometry and a Profile operation.
I tried that and it wanted to take out everything including the picture
Can you show a screenshot of what you’re trying to achieve, or share the .mage file?
To cut out a pocket around the outside of the logo, you would draw two rectangles, create a Pocket operation, and assign the two rectangles to that operation.
You may be looking for vcarving - this feature isn’t yet available in MillMage, but when we release MillMage Pro in the near future, it will be - you can see development of those features here: Relief Carving - Work in Progress
I’d strongly recommend that any new user like yourself start with the guides we have in our documentation here: Project Setup Wizard: Beginner - MillMage Documentation
For that I recommend using the Offset tool
It makes a nice border, which you could then use as the inner boundary of your pocket:
We have a video for how to use this tool here: https://www.youtube.com/watch?v=rEJ7ntlmEyU - it’s for LightBurn, but functions the same in MillMage
HD offset.mage (342.7 KB)
OK thank you got it working apparently it doesn’t like small letters, I had to enlarge to 12”x10” with a .1 v-bit to carve out the middle of the A and R but the offset worked very well
Once we make V-carving available to with MillMage Pro you’ll be able to do much-improved letter carving ![]()
is this what you are trying to achieve, the way i worked it out.
is ungroup the file , select outside line change colour to match your out line boarder colour than re group
than set operation auto use layer colour to on
when assign operation click on outside boarder not the object as it is grouped
do full preview run of job
i did 2 relief pockets to get the fine detail
Yes, that is what I’m trying for, looks like I might have it just haven’t had a chance to run it yet, thank you
that’s beautiful by the way
Thank you .
