I don’t care about offending people, I only care about helping those users that have been misinformed and are in this case, blaming themselves over issues that are not their own. I talk to other LB users out side of this place, it’s been helpful since I can correlate in a true and unbiased atmosphere. It’s also helping them stick with it rather then give up and tell others to not use the software.
I am not being paid, nor would I accept payment to debug the software with the developers, to include sharing all of my findings and issues as I design away, in addition to, I just don’t have the time for that.
Rule of thumb as stated, check your work as you go along. Also, as stated, do not believe everything people are saying in their forums for support, not all of them are who they make you think they are, they have an agenda and I’m the one in the wrong for pointing this out, what ever…
The plane would have been done much more quickly if I knew then what I know now along software trust, there was much I had to redraw that I should not have, but I won’t have to do that in the future now. I was smart enough to not attempt a tab and slot system with the forward sheeting since LB can’t handle it and you are stuck trial and error after the fact that I just don’t have the patience, nor desire to do any more, that is something I may still go back to regardless… this was an element I’ve already brought to the support system as you say, so far, zero solutions were found… The cockpit sheeting, well and above this in addition to ask upon in addition, it’s a necessary part to keep this functional and scale of some degree, this is only the first mostly scratch by hand work around version, but LB was the basis for it’s design, now it get’s more refined in it for future generations of this bird because it simply cannot be programmed in perfectly and dead on, correctly in the software alone.
I am most irritated with the sock puppet responses then the nuances and work around with the software’s limitations, at least what I bring to the table has constructive direction and making it loud and clear, I’m not buying into the gas-lighting going on…
