I have an OLM3 with the Ortur 400 x 850 extension and am having problems with the machine stopping mid-cut. The part that I’m cutting is well within the cut area but I get the following when it stops:
“G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 183:”
I’ve tried several different files (all in DXF format) and have been running into the same problem. The last time I was able to cut the part the first time and it faulted when I tried to cut the second time without changing anything. Any suggestions as to what to do? Getting really frustrated.
Thank you, I’ll give that a try. I have been able to frame all of the items and what really confuses me is that I cut properly once and then halted on the next attempts.
