Cut-through delay and fill mode
A non-zero pause value in cut-through mode pauses the start of the movement even if cut-through isn’t enabled. Also, the same layer changed to fill from cut experiences the same behavior although the pause value isn’t visible and can’t be changed.
v 0.9.10 and 0.9.11. Is this intentional?
The pause on fill isn’t (and I believe has been fixed already). The pause on line mode even with Cut-Through disabled is intentional. The toggle is choosing whether or not to enable the beam - non-zero numbers in the start / end delay will always pause, though it didn’t always - this change was added in 0.9.10.
