Cut vertical lines first, than horizontal ones
Hi, I have a sticker grid created by grid tool
obrazek
and for unknown reason some stickers are not square at the end (probably some material issue). So I thought I might try to cut vertical lines first and than horizontal ones - long straight cut.
Is it possible to order this kind of cut? I did multiple experiments with cut optimalization, but with no luck.
I am aware that I might get this by designing the grid manually, but I am looking for the sollution using grid tool.
Thank you for your tips
Did you test the “remove overlapping lines” feature? If there are any overlapping lines, but if I recall correctly, I had a similar outcome then. Though this might have been coincidental.
This recent topic seems closely related:
Thanks, this was turned on, helped a lot, but not 100%
Thanks. this helped. I have created a different object than rectangle, multiplied by grid tool and voila…
