I want to make a wooden stamp. I have my logo which i traced in LB. I figured the way i could possibly do it, is to create a rectangle, drop the traced logo inside and then either boolean union / subtract, which ever of these would work the best. However im finding this wont work.
Any advice on how to subtract the logo away from a shape. Im going to engrave the area around the logo so the logo stands proud from the material and burn away the rest.
You definitely want to do a boolean difference subtracting the logo from the background rectangle. This will leave you with the area that you want to engrave.
Boolean operations only work with 2 objects. You may need to group the items in the logo to make sure it’s acting as a single object
Boolean operations only work with closed path shapes. Make sure the logo doesn’t have any loose ends although it shouldn’t coming out of a trace operation.
If you need some more help drop the .lbrn file here and I’m sure someone can take a look.
