Cutting letters burn path
Hi,
When cutting a word from MDF I notice the laser cuts the outline shape and then returns to cut the inner parts last. For example, if I cut the name “Jake” and run 3 passes. The letters ‘a’ and ‘e’ have inner parts. These small semi-circles will have 3 passes one after the other. This puts them under high constant exposure, which is causing burn marks on the final product.
Is there a solution to this that doesn’t involve running the laser for one pass at a time? For example, can I set the laser to cut the entire design before restarting for the second pass?
Thanks,
Jake
Read the following topic.
