Yes. But thats what i need for Lines.
Otherwise I always get points at the corners and I want to avoid that.
If I engrave with very little power, the corners are cut out because the laser slows down here. However, it should only do this behind the line so that exactly this problem does not occur.
As the laser begins to decelerate into the corner the power will also begin to be reduced down to as low as the Min Power value - which can be optionally set to right down to a value as low as your laser can still fire at.
Okay that would help with the example above,
but I don’t think it will help me with my problem of cutting out exactly.
I have a special film that absorbs light and it would be bad if there are holes at the corners. Sounds perhaps a bit trivial, but the film is very expensive and should absorb the light in a camera and there you would see the small holes then probably. The customer is very meticulous.
That’s why I thought of the overscanning function only for lines.
The laser accelerates a little before the actual cut and brakes only after the cut. So there should be no holes.
Laser power compensation during acceleration/deceleration is handled by your controller. However, the controller will not go below the Min power specified in the Cut setting for that compensation. These features are specifically meant to compensate for overburning scenarios.
With a dsp controller, the hardware figures out the ‘overscan’ for you… you have no control over that… Ever get the ‘slop’ error… that’s generally it’s computed overscan going outside the defined work area.
You might want to keep in mind how power is applied with the different settings… The red line is the change in power/speed.
Thanks first of all for the answers to all of you.
The laser has 60 watts.
My problem is that if the power is too low, the foil does not cut properly but starts to melt.
With 40% power I get a nice and clean cut. But not at the corners.
If I lower the power here, the foil will melt again. And I don’t have much space for testing because the foil is expensive.
I have never had any problems with this, but it is very noticeable here and I can’t sell it with holes in the corners.
I would not have thought that it would cause such a problem. Unfortunately, a lead in is not possible because I need the outer and inner edges of the film.
I’ll have to have a look at the setting for the start speed on the controller.
