Hi, I created a design outside of Lightburn then moved it to lightburn when I go to run it the laser stops then starts again.
When I created the design in lightburn it will run it.
I have looked at videos, checked out chat groups followed all the troubleshooting tips and nothing is working. I even did a software update. HELP.
I am a teenager and my mom and dad are both trying to help me figure this out. None of us can do it.
Can you upload the problem .lbrn file here for review?
Ronald G WADE.lbrn2 (99.6 KB)
I don’t see anything obviously broken in the file. Speeds for the image component are a bit low but should still work without issue.
Can you describe the issue you’re seeing in depth? Does the job complete normally?
Also, please confirm if you have the latest firmware updated for your laser. Also, confirm the laser you’re using is the xTool D1 that’s listed in your profile.
i do have Xtool D1 ten watt
99% sure it is updated
it frames properly but when i press start it goes to where it should start engraving and just stops and does not move. And it’s only this because i made i different design and it worked
Stops implies that it was at one point moving. Can you elaborate?
What happens once there’s no movement? How do you recover?
Can you open the Console window and run this command? Then return the results here.
$I
it gets in position to start engraving and starts and makes a clunk sound (even though there’s nothing blocking it) and resets itself so it’s back to framing mode.
ok
start_home x
set_SGTHRS x (50)
enable x limit
x limit trigged
start_home y
set_SGTHRS y (50)
enable y limit
y limit trigged
MPos:0.000000,0.000000,0.000000
$I
ok
ok
[XTool D1:ver 40.30.003.01 B9]
$I
ok
ok
Okay. This should be a relatively current firmware as far as I know.
This is odd.
Can you get your job ready to burn but then instead of running the job, push “Save Gcode” in Laser window. Then save to a file with a .txt extension and upload here please.
part 1
; LightBurn 1.1.04
; GRBL device profile, current position
; Bounds: X0.68 Y1.27 to X49.82 Y33.27
G00 G17 G40 G21 G54
G91
M4
; Image @ 46 mm/min, 50% power
M8
G0 X4.681Y33.266
; Layer C00
G1 X0.019F46S0
G1 X0.1S500
G1 X5.9S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X12.5S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X8.3S0
G1 X0.1S500
G1 X0.019S0
G1 X1.7Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-9S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-16.2S0
G1 X-0.1S500
G1 X-8.4S0
G1 X-0.1S500
G1 X-3S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-0.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X4.4S0
G1 X0.1S500
G1 X5.3S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X3.3S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X2.6S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X12.5S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X0.019S0
G1 X-1Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-8.3S0
G1 X-0.1S500
G1 X-8.9S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-3.8S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-2.3Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X4.9S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X2.6S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X3.9S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X10.2S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X3.1S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X1.6S0
G1 X0.1S500
G1 X0.019S0
G1 X-10.3Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-8.9S0
G1 X-0.1S500
G1 X-3.9S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.1S500
G1 X-3.3S0
G1 X-0.1S500
G1 X-3.4S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-4.9S0
G1 X-0.1S500
G1 X-0.019S0
G1 X9.5Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X12.6S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X2.6S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X4.3S0
G1 X0.1S500
G1 X13S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.019S0
G1 X0.3Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-2.4S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-7S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-3.9S0
G1 X-0.1S500
G1 X-11.4S0
G1 X-0.1S500
G1 X-12S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-0.4Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X10.2S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X10.4S0
G1 X0.1S500
G1 X3.7S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X3.8S0
G1 X0.1S500
G1 X9.3S0
G1 X0.1S500
G1 X3S0
G1 X0.1S500
G1 X0.019S0
G1 X-4.1Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-5.4S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-2.7S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-3.7S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-3.7S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-2.7S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-2Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X4.7S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X3S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X6.1S0
G1 X0.1S500
G1 X9.8S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X4.7S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X0.019S0
G1 X1.6Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-4.2S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-16.1S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.1S500
G1 X-6.8S0
G1 X-0.1S500
G1 X-0.019S0
G1 X5.1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X4.8S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X11.8S0
G1 X0.1S500
G1 X3.3S0
G1 X0.1S500
G1 X5.5S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X5.6S0
G1 X0.1S500
G1 X5S0
G1 X0.1S500
G1 X0.019S0
G1 X-3.9Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-6.1S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-8S0
G1 X-0.1S500
G1 X-5.6S0
G1 X-0.1S500
G1 X-4.2S0
G1 X-0.1S500
G1 X-10S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-4.9Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X6.1S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X3.1S0
G1 X0.1S500
G1 X10.1S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X4.7S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X8.6S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X0.019S0
G1 X0.3Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-5.6S0
G1 X-0.1S500
G1 X-7.4S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-12S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-6.5S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-0.019S0
G1 X0.9Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X3.8S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X8.8S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X2.9S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X3S0
G1 X0.1S500
G1 X10.3S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X5.1S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.019S0
G1 X2.6Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-3.5S0
G1 X-0.1S500
G1 X-6S0
G1 X-0.1S500
G1 X-8.8S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-3S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-4.5S0
G1 X-0.1S500
G1 X-3.3S0
part 2
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-0.4Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X4.3S0
G1 X0.1S500
G1 X6S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X7.7S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X3.5S0
G1 X0.1S500
G1 X6.4S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X8.8S0
G1 X0.1S500
G1 X0.019S0
G1 X-4.9Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-5.5S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-8.1S0
G1 X-0.1S500
G1 X-8.9S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-4.9S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-4.4S0
G1 X-0.1S500
G1 X-0.019S0
G1 X15.1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X12.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X5.8S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X0.019S0
G1 X3.4Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-2.7S0
G1 X-0.1S500
G1 X-9S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-7.5S0
G1 X-0.1S500
G1 X-9.2S0
G1 X-0.1S500
G1 X-3.1S0
G1 X-0.1S500
G1 X-3.1S0
G1 X-0.1S500
G1 X-5.2S0
G1 X-0.1S500
G1 X-0.019S0
G1 X0.8Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X3.3S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X3.9S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X6.8S0
G1 X0.1S500
G1 X8S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X0.019S0
G1 X1.5Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-3S0
G1 X-0.1S500
G1 X-3.7S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-6.4S0
G1 X-0.1S500
G1 X-3.1S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-5.3S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-3.3S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-3.4S0
G1 X-0.1S500
G1 X-4.9S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X3.4S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X7.6S0
G1 X0.1S500
G1 X4.4S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X5.6S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X4.6S0
G1 X0.1S500
G1 X3.5S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X5.8S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X0.019S0
G1 X-4.8Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-5.5S0
G1 X-0.1S500
G1 X-8.2S0
G1 X-0.1S500
G1 X-6.2S0
G1 X-0.1S500
G1 X-2.7S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-3.8S0
G1 X-0.1S500
G1 X-6.8S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.019S0
G1 X4.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X14.8S0
G1 X0.1S500
G1 X3.1S0
G1 X0.1S500
G1 X10S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X5S0
G1 X0.1S500
G1 X0.019S0
G1 X6.5Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-6.4S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-16.2S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-3S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-3.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X7.6S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X12.6S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X0.019S0
G1 X-6.7Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-7.6S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-8.1S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-6.8S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.019S0
G1 X3.2Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X3.1S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X3.8S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X4.2S0
G1 X0.1S500
G1 X8.2S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X7S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.019S0
G1 X-0.8Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-2.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-8.1S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-11.7S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.019S0
G1 X9Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X4S0
G1 X0.1S500
G1 X18S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X1.6S0
G1 X0.1S500
G1 X3.3S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X3.7S0
G1 X0.1S500
G1 X0.019S0
G1 X-9.6Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-7.6S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-5.3S0
G1 X-0.1S500
G1 X-4.4S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-4.4S0
G1 X-0.1S500
G1 X-0.019S0
G1 X0.9Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X9.4S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X13.1S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.019S0
G1 X0.3Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-2.7S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-3.5S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-4.9S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-2.7S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-3.1S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
pt 33G1 X-2.6S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-0.019S0
G1 X1.8Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X3.3S0
G1 X0.1S500
G1 X5.6S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X6.6S0
G1 X0.1S500
G1 X5.9S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.019S0
G1 X2.2Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-6.5S0
G1 X-0.1S500
G1 X-7.8S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-4S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-7.5S0
G1 X-0.1S500
G1 X-3.5S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-0.6Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X3.9S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X6S0
G1 X0.1S500
G1 X7.1S0
G1 X0.1S500
G1 X5.5S0
G1 X0.1S500
G1 X4.6S0
G1 X0.1S500
G1 X2.6S0
G1 X0.1S500
G1 X2.9S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.019S0
G1 X0.3Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-12.4S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-9S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-5.2S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-11.6Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X4S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X10.7S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.9S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X6.8S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.019S0
G1 X6.8Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-5.5S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-4.2S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-9.7S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-0.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X4.7S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X8.9S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X4.6S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X4.3S0
G1 X0.1S500
G1 X3.5S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X3.3S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X3.1S0
G1 X0.1S500
G1 X0.019S0
G1 X-2.4Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-22.3S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-3.3S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-7.1S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-2.5Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X5.6S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X5.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X1.6S0
G1 X0.1S500
G1 X6.4S0
G1 X0.1S500
G1 X1.6S0
G1 X0.1S500
G1 X4.3S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X5.5S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X0.019S0
G1 X2.5Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-6.7S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-6.9S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-4.5S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-7.9S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-7.9S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-0.9Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X5.9S0
G1 X0.1S500
G1 X4S0
G1 X0.1S500
G1 X5.9S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X3.3S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X13.8S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X0.019S0
G1 X-2Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-4.6S0
G1 X-0.1S500
G1 X-7S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-4.4S0
G1 X-0.1S500
G1 X-6.4S0
G1 X-0.1S500
G1 X-5.7S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-3.4S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-4.7S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-0.5Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X4.9S0
G1 X0.1S500
G1 X5.9S0
G1 X0.1S500
G1 X5.8S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X5.6S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X3S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X0.019S0
G1 X-4.9Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-4.7S0
G1 X-0.1S500
G1 X-4.7S0
G1 X-0.1S500
G1 X-6.7S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-4.7S0
G1 X-0.1S500
G1 X-7.5S0
G1 X-0.1S500
G1 X-0.019S0
G1 X2.1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X3.7S0
G1 X0.1S500
G1 X7.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X4.8S0
G1 X0.1S500
G1 X1.5S0
G1 X0.3S500
G1 X1.9S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X4.5S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.019S0
G1 X4.4Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-4.3S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-5.7S0
G1 X-0.1S500
G1 X-4.4S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.7S500
G1 X-9.4S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-6.5Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X8.9S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X5.7S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X1.8S0
G1 X0.7S500
G1 X1.1S0
G1 X0.1S500
G1 X3.8S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X4.4S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X7.4S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X0.019S0
G1 X0.4Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-5.3S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-4.5S0
G1 X-0.8S500
G1 X-6.6S0
G1 X-0.1S500
G1 X-5.9S0
G1 X-0.1S500
G1 X-6.1S0
G1 X-0.1S500
G1 X-2.4S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-2.4Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X4.2S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X3S0
G1 X0.1S500
G1 X9.6S0
G1 X0.1S500
G1 X2.1S0
pt4
G1 X0.1S500
G1 X0.5S0
G1 X0.8S500
G1 X2.7S0
G1 X0.1S500
G1 X9.7S0
G1 X0.1S500
G1 X8.5S0
G1 X0.1S500
G1 X0.019S0
G1 X-3.3Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-7.7S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-3.8S0
G1 X-0.9S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-4.6S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-6S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-3.1S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-0.019S0
G1 X2Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X5.4S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X3.2S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X4S0
G1 X0.8S500
G1 X6.8S0
G1 X0.1S500
G1 X4.6S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X6.2S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X4.5S0
G1 X0.1S500
G1 X0.019S0
G1 X-4.1Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-14.3S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.7S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-4.5S0
G1 X-0.1S500
G1 X-5.6S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-6.1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X10S0
G1 X0.1S500
G1 X6.8S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X2.1S0
G1 X0.7S500
G1 X5.9S0
G1 X0.1S500
G1 X5S0
G1 X0.1S500
G1 X10.8S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.019S0
G1 X0.4Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-9.4S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-4.4S0
G1 X-0.5S500
G1 X-6.8S0
G1 X-0.1S500
G1 X-4.5S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-5.2S0
G1 X-0.1S500
G1 X-4.6S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-0.019S0
G1 X0.3Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X13.7S0
G1 X0.1S500
G1 X4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.7S0
G1 X0.4S500
G1 X2.9S0
G1 X0.1S500
G1 X17.5S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X1.6S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X0.019S0
G1 X-16.9Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-3.9S0
G1 X-0.3S500
G1 X-5.7S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-13.9S0
G1 X-0.1S500
G1 X-0.019S0
G1 X1.6Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X13.2S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X6.1S0
G1 X0.6S500
G1 X23.4S0
G1 X0.1S500
G1 X0.019S0
G1 X-20.3Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-3S0
G1 X-0.4S500
G1 X-0.1S0
G1 X-0.4S500
G1 X-9.3S0
G1 X-0.1S500
G1 X-12S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-1.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X16.5S0
G1 X0.1S500
G1 X6.3S0
G1 X0.5S500
G1 X0.3S0
G1 X0.5S500
G1 X6.4S0
G1 X0.1S500
G1 X15.1S0
G1 X0.1S500
G1 X0.019S0
G1 X0.5Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-22S0
G1 X-0.4S500
G1 X-0.7S0
G1 X-0.4S500
G1 X-0.019S0
G1 X-22.4Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X7.7S0
G1 X1S500
G1 X0.1S0
G1 X0.1S500
G1 X0.1S0
G1 X0.1S500
G1 X13S0
G1 X0.5S500
G1 X0.9S0
G1 X0.5S500
G1 X13S0
G1 X1.2S500
G1 X0.2S0
G1 X0.1S500
G1 X0.019S0
G1 X8.7Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-7.2S0
G1 X-2.8S500
G1 X-12.1S0
G1 X-0.4S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.5S500
G1 X-12.1S0
G1 X-2.7S500
G1 X-8.1S0
G1 X-0.1S500
G1 X-0.019S0
G1 X1.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X0.1S0
G1 X1.9S500
G1 X1.7S0
G1 X1S500
G1 X0.1S0
G1 X0.2S500
G1 X0.1S0
G1 X0.2S500
G1 X0.1S0
G1 X1.8S500
G1 X6S0
G1 X0.1S500
G1 X5.3S0
G1 X0.6S500
G1 X0.9S0
G1 X0.1S500
G1 X0.5S0
G1 X0.5S500
G1 X11.3S0
G1 X1.6S500
G1 X0.1S0
G1 X0.1S500
G1 X0.1S0
G1 X0.1S500
G1 X0.2S0
G1 X0.1S500
G1 X0.1S0
G1 X1.3S500
G1 X1.4S0
G1 X0.1S500
G1 X0.1S0
G1 X1.9S500
G1 X4.6S0
G1 X0.1S500
G1 X0.019S0
G1 X-0.9Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-3S0
G1 X-3.5S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-0.2S0
G1 X-0.7S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-0.2S0
G1 X-1.2S500
G1 X-10.5S0
G1 X-0.7S500
G1 X-1.8S0
G1 X-0.7S500
G1 X-10.6S0
G1 X-1.1S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-2.4S0
G1 X-0.7S500
G1 X-0.2S0
G1 X-0.1S500
G1 X-0.1S0
G1 X-3.5S500
G1 X-0.019S0
G1 X-3.1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X1.9S0
G1 X1.3S500
G1 X0.1S0
G1 X0.1S500
G1 X0.2S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.2S0
G1 X0.1S500
G1 X0.4S0
G1 X1.8S500
G1 X3.4S0
G1 X1.1S500
G1 X9.8S0
G1 X0.8S500
G1 X0.6S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X0.5S0
G1 X0.9S500
G1 X9.7S0
G1 X1S500
G1 X3.6S0
G1 X1.5S500
G1 X0.1S0
G1 X0.1S500
G1 X0.2S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X0.2S0
G1 X0.1S500
G1 X0.2S0
G1 X0.1S500
G1 X0.1S0
G1 X1.2S500
G1 X0.019S0
G1 X0.3Y-0.1S0
G1 X-0.019S0
G1 X-0.8S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-1.2S500
G1 X-3.7S0
G1 X-0.9S500
G1 X-9S0
G1 X-0.9S500
G1 X-2.7S0
G1 X-1S500
G1 X-9S0
G1 X-1S500
G1 X-3.5S0
G1 X-1.2S500
G1 X-1S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.8S500
G1 X-0.019S0
G1 X-0.2Y-0.1S0
G1 X0.019S0
G1 X0.6S500
G1 X3.6S0
G1 X0.4S500
G1 X0.2S0
G1 X1.1S500
G1 X3.6S0
G1 X0.9S500
G1 X8.3S0
G1 X1.1S500
G1 X3S0
G1 X1.2S500
G1 X8.3S0
G1 X0.8S500
G1 X3.7S0
G1 X1S500
G1 X0.2S0
G1 X0.4S500
G1 X3.7S0
G1 X0.6S500
G1 X0.019S0
G1 X3.3Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-2.4S0
G1 X-0.6S500
G1 X-3.7S0
G1 X-0.4S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.1S0
G1 X-1S500
G1 X-3.6S0
G1 X-1.1S500
G1 X-7.2S0
G1 X-1.3S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-1.3S500
G1 X-7.3S0
G1 X-1.1S500
G1 X-3.6S0
G1 X-0.7S500
G1 X-0.1S0
G1 X-0.2S500
G1 X-0.7S0
G1 X-0.4S500
G1 X-3.8S0
G1 X-0.6S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-0.019S0
G1 X2.4Y-0.1S0
G1 X0.019S0
G1 X0.6S500
G1 X2.2S0
G1 X0.1S500
G1 X1.6S0
G1 X0.3S500
G1 X1.2S0
G1 X0.1S500
G1 X0.2S0
G1 X0.9S500
G1 X3.7S0
G1 X1.2S500
G1 X6S0
G1 X0.1S500
G1 X0.1S0
G1 X1.5S500
G1 X3.9S0
G1 X0.1S500
G1 X0.1S0
G1 X1.5S500
G1 X0.1S0
G1 X0.2S500
G1 X5.8S0
G1 X1.3S500
G1 X3.5S0
G1 X1.1S500
G1 X0.2S0
G1 X0.1S500
G1 X1.1S0
G1 X0.4S500
G1 X2.6S0
G1 X0.1S500
G1 X1.2S0
G1 X0.5S500
G1 X0.019S0
G1 X1.8Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.5S500
G1 X-0.2S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.4S500
G1 X-2S0
G1 X-0.9S500
G1 X-3.8S0
G1 X-1.5S500
G1 X-4.3S0
G1 X-1.2S500
G1 X-0.1S0
G1 X-0.9S500
G1 X-4.8S0
G1 X-1.7S500
G1 X-0.1S0
G1 X-0.3S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-4.2S0
G1 X-1.5S500
G1 X-3.8S0
G1 X-1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.4S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-2.9S0
G1 X-0.4S500
G1 X-0.019S0
G1 X-1.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X1.1S0
G1 X0.4S500
G1 X1.1S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X2.3S0
G1 X0.5S500
G1 X0.8S0
G1 X0.1S500
G1 X1.3S0
G1 X1S500
G1 X4S0
G1 X2.1S500
G1 X0.1S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X0.1S0
G1 X3.5S500
pt5
G1 X3.3S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X1.7S0
G1 X0.9S500
G1 X0.1S0
G1 X0.1S500
G1 X0.1S0
G1 X2S500
G1 X0.1S0
G1 X0.1S500
G1 X0.1S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X0.1S0
G1 X2.2S500
G1 X4S0
G1 X0.9S500
G1 X0.5S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X0.8S0
G1 X0.5S500
G1 X1.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X1S0
G1 X0.4S500
G1 X0.019S0
G1 X0.1Y-0.1S0
G1 X-0.019S0
G1 X-0.3S500
G1 X-4.2S0
G1 X-0.6S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-1.3S500
G1 X-3.9S0
G1 X-0.1S500
G1 X-0.2S0
G1 X-4S500
G1 X-0.1S0
G1 X-0.2S500
G1 X-0.1S0
G1 X-0.2S500
G1 X-0.1S0
G1 X-1.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-1S0
G1 X-1.6S500
G1 X-0.1S0
G1 X-0.2S500
G1 X-0.1S0
G1 X-3.5S500
G1 X-0.1S0
G1 X-0.2S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-4.1S0
G1 X-1.2S500
G1 X-2.7S0
G1 X-0.5S500
G1 X-3.3S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.3S500
G1 X-0.019S0
G1 X-2Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X1.7S0
G1 X0.4S500
G1 X2.3S0
G1 X0.1S500
G1 X1.8S0
G1 X0.6S500
G1 X3S0
G1 X0.1S500
G1 X0.1S0
G1 X1.5S500
G1 X4.7S0
G1 X0.1S500
G1 X0.1S0
G1 X0.1S500
G1 X0.1S0
G1 X0.3S500
G1 X0.1S0
G1 X0.2S500
G1 X0.2S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.7S0
G1 X1.7S500
G1 X0.1S0
G1 X0.1S500
G1 X1.6S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X3.4S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.2S0
G1 X1.3S500
G1 X0.1S0
G1 X0.1S500
G1 X0.1S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X0.2S0
G1 X0.1S500
G1 X0.3S0
G1 X0.7S500
G1 X0.1S0
G1 X0.1S500
G1 X0.2S0
G1 X0.1S500
G1 X4.6S0
G1 X1.4S500
G1 X0.1S0
G1 X0.1S500
G1 X3.2S0
G1 X0.6S500
G1 X4.1S0
G1 X0.5S500
G1 X1.9S0
G1 X0.1S500
G1 X0.019S0
G1 X-1.9Y-0.1S0
G1 X-0.019S0
G1 X-0.5S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.6S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-0.2S0
G1 X-0.1S500
G1 X-0.1S0
G1 X-1.6S500
G1 X-5.9S0
G1 X-1.7S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-6.2S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-1.7S500
G1 X-5.9S0
G1 X-1.6S500
G1 X-3.8S0
G1 X-0.7S500
G1 X-4.1S0
G1 X-0.5S500
G1 X-0.019S0
G1 X-0.1Y-0.1S0
G1 X0.019S0
G1 X0.6S500
G1 X4.1S0
G1 X0.7S500
G1 X1.6S0
G1 X0.1S500
G1 X2.8S0
G1 X1.9S500
G1 X3.9S0
G1 X0.1S500
G1 X0.1S0
G1 X1.8S500
G1 X4.7S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X0.7S0
G1 X2S500
G1 X4.1S0
G1 X1.9S500
G1 X4.5S0
G1 X0.7S500
G1 X4.1S0
G1 X0.6S500
G1 X1.2S0
G1 X0.1S500
G1 X0.019S0
G1 X-1.2Y-0.1S0
G1 X-0.019S0
G1 X-0.7S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.7S500
G1 X-5.1S0
G1 X-6.6S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-8.4S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-6.5S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.8S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.6S500
G1 X-0.019S0
G1 X-1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.9S0
G1 X0.6S500
G1 X0.7S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X0.5S0
G1 X0.8S500
G1 X2.1S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X0.1S0
G1 X0.2S500
G1 X0.1S0
G1 X0.2S500
G1 X0.1S0
G1 X4.3S500
G1 X0.1S0
G1 X0.2S500
G1 X0.6S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X4.3S0
G1 X0.1S500
G1 X5.6S0
G1 X0.1S500
G1 X0.2S0
G1 X0.2S500
G1 X0.1S0
G1 X4.5S500
G1 X0.1S0
G1 X0.1S500
G1 X0.2S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X1.1S0
G1 X0.8S500
G1 X1S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.5S0
G1 X0.6S500
G1 X0.019S0
G1 X0.1Y-0.1S0
G1 X-0.019S0
G1 X-0.7S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.8S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-0.2S0
G1 X-0.1S500
G1 X-0.2S0
G1 X-0.1S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-0.2S0
G1 X-0.1S500
G1 X-0.2S0
G1 X-0.1S500
G1 X-0.2S0
G1 X-0.1S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-0.2S0
G1 X-0.1S500
G1 X-0.2S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-4.2S0
G1 X-0.1S500
G1 X-8.1S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-0.1S0
G1 X-0.2S500
G1 X-0.1S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.2S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-3.9S0
G1 X-0.8S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.7S500
G1 X-0.019S0
G1 X-1.5Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X1.3S0
G1 X0.8S500
G1 X1.6S0
G1 X0.1S500
G1 X2.3S0
G1 X0.8S500
G1 X6.3S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X5.6S0
G1 X0.1S500
G1 X7.4S0
G1 X0.1S500
G1 X0.7S0
G1 X0.9S500
G1 X3.6S0
G1 X0.1S500
G1 X0.3S0
G1 X0.8S500
G1 X1.5S0
G1 X0.1S500
G1 X0.019S0
G1 X-1.6Y-0.1S0
G1 X-0.019S0
G1 X-0.8S500
G1 X-1S0
G1 X-0.1S500
G1 X-2.9S0
G1 X-0.9S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-5S0
G1 X-0.1S500
G1 X-9.2S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.9S500
G1 X-2S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.7S500
G1 X-0.019S0
G1 X-0.1Y-0.1S0
G1 X0.019S0
G1 X0.9S500
G1 X2.3S0
G1 X0.1S500
G1 X1.6S0
G1 X0.9S500
G1 X5.5S0
G1 X0.1S500
G1 X6.3S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X1.6S0
G1 X0.1S500
G1 X3.2S0
G1 X0.1S500
G1 X3.3S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X8.7S0
G1 X0.1S500
G1 X1.7S0
G1 X0.9S500
G1 X4S0
G1 X0.9S500
G1 X0.9S0
G1 X0.1S500
G1 X0.019S0
G1 X-1Y-0.1S0
G1 X-0.019S0
G1 X-0.8S500
G1 X-4.1S0
G1 X-0.9S500
G1 X-4.5S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-3.7S0
G1 X-0.1S500
G1 X-4.9S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-8.1S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-3.1S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-1S500
G1 X-4S0
G1 X-0.9S500
G1 X-0.019S0
G1 Y-0.1S0
G1 X0.019S0
G1 X0.9S500
G1 X0.7S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X1S0
G1 X1S500
G1 X2.5S0
G1 X0.1S500
G1 X4.1S0
G1 X0.1S500
G1 X3.5S0
G1 X0.1S500
G1 X6.1S0
G1 X0.1S500
G1 X4.9S0
G1 X0.1S500
G1 X2.9S0
G1 X0.1S500
G1 X7.3S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X0.3S0
G1 X1S500
G1 X1S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.3S0
G1 X1S500
G1 X0.019S0
G1 Y-0.1S0
G1 X-0.019S0
G1 X-0.9S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-2.4S0
G1 X-1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-4.7S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-3.9S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-6.1S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-5.7S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-3.5S0
G1 X-1S500
G1 X-0.019S0
G1 X-1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.9S0
G1 X1S500
G1 X1.1S0
G1 X0.1S500
G1 X2.8S0
G1 X1S500
G1 X0.8S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
pt6
G1 X0.9S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X8.1S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X3.3S0
G1 X1S500
G1 X0.5S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X2.1S0
G1 X1S500
G1 X1.3S0
G1 X0.1S500
G1 X0.019S0
G1 X-1.4Y-0.1S0
G1 X-0.019S0
G1 X-1S500
G1 X-4.1S0
G1 X-0.8S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-3.1S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-4.4S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-5.4S0
G1 X-0.1S500
G1 X-8.5S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.8S500
G1 X-4.1S0
G1 X-1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.019S0
G1 X0.3Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.3S0
G1 X1S500
G1 X1.4S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X1.8S0
G1 X0.8S500
G1 X5.2S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X5.8S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X11S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X2S0
G1 X0.8S500
G1 X3.6S0
G1 X0.1S500
G1 X0.4S0
G1 X1S500
G1 X0.8S0
G1 X0.1S500
G1 X0.019S0
G1 X-0.8Y-0.1S0
G1 X-0.019S0
G1 X-1.1S500
G1 X-4.3S0
G1 X-0.5S500
G1 X-11.5S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-5S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-8.9S0
G1 X-0.1S500
G1 X-4.8S0
G1 X-0.4S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-1.1S500
G1 X-0.019S0
G1 Y-0.1S0
G1 X0.019S0
G1 X1.1S500
G1 X2.6S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X3.9S0
G1 X0.1S500
G1 X3.7S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X3S0
G1 X0.1S500
G1 X7S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X3.3S0
G1 X0.1S500
G1 X4.7S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X1.1S0
G1 X1.1S500
G1 X0.019S0
G1 Y-0.1S0
G1 X-0.019S0
G1 X-1.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-2.4S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-3.3S0
G1 X-0.1S500
G1 X-3S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-7.4S0
G1 X-0.1S500
G1 X-9.2S0
G1 X-0.1S500
G1 X-2.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-3S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-1.1S500
G1 X-0.019S0
G1 X-1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.9S0
G1 X1.2S500
G1 X4.3S0
G1 X0.1S500
G1 X3.2S0
G1 X0.1S500
G1 X5.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X1.6S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X4.7S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X3.5S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X2.1S0
G1 X1.2S500
G1 X0.019S0
G1 X1.4Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-1.2S500
G1 X-5.3S0
G1 X-0.1S500
G1 X-3S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-6.7S0
G1 X-0.1S500
G1 X-4.9S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-4.8S0
G1 X-1.1S500
G1 X-0.019S0
G1 X-0.5Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.4S0
G1 X1.1S500
G1 X0.9S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X5.8S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X5.7S0
G1 X0.1S500
G1 X4.7S0
G1 X0.1S500
G1 X2.9S0
G1 X0.1S500
G1 X5.1S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X3.4S0
G1 X0.1S500
G1 X0.8S0
G1 X1.1S500
G1 X0.8S0
G1 X0.1S500
G1 X0.019S0
G1 X-0.5Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-1.1S500
G1 X-10.6S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-6.5S0
G1 X-0.1S500
G1 X-5.5S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-7.8S0
G1 X-0.1S500
G1 X-10.3S0
G1 X-1.1S500
G1 X-0.019S0
G1 X0.1Y-0.1S0
G1 X0.019S0
G1 X1S500
G1 X2.9S0
G1 X0.1S500
G1 X6.3S0
G1 X0.1S500
G1 X14.9S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X4.5S0
G1 X0.1S500
G1 X4.2S0
G1 X0.1S500
G1 X5.1S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X0.4S0
G1 X1S500
G1 X0.019S0
G1 X-0.1Y-0.1S0
G1 X-0.019S0
G1 X-0.8S500
G1 X-2S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-12.2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-2.7S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-7.1S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-7.7S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-5.3S0
G1 X-0.9S500
G1 X-0.019S0
G1 X-1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X0.4S0
G1 X0.5S500
G1 X2.7S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X6.2S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X3.1S0
G1 X0.1S500
G1 X5.1S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X6.2S0
G1 X0.6S500
G1 X0.019S0
G1 X-5.5Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-8.9S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-12.1S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-3.9S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-0.019S0
G1 X1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X6.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X9.8S0
G1 X0.1S500
G1 X4.7S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X4.7S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X1.6S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X3S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X1.9S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X0.019S0
G1 X-2Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-2.7S0
G1 X-0.1S500
G1 X-6.2S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-4.8S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-3S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-5.9S0
G1 X-0.1S500
G1 X-9.5S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-0.8Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X15.5S0
G1 X0.1S500
G1 X6.5S0
G1 X0.1S500
G1 X3.2S0
G1 X0.1S500
G1 X6.6S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
pt7
G1 X4.8S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.019S0
G1 X-2.1Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-9.5S0
G1 X-0.1S500
G1 X-2.9S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-8.9S0
G1 X-0.1S500
G1 X-5S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-3.8S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-4.1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X6.5S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X10.5S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X4.9S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X5.8S0
G1 X0.1S500
G1 X0.019S0
G1 X-8.1Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-4S0
G1 X-0.1S500
G1 X-5.2S0
G1 X-0.1S500
G1 X-6.3S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-4.3S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-0.019S0
G1 X1.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X10.2S0
G1 X0.1S500
G1 X7.8S0
G1 X0.1S500
G1 X5.1S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X11.9S0
G1 X0.1S500
G1 X3.3S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X0.019S0
G1 X0.6Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-8.7S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-4.2S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-2.9S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-4.3S0
G1 X-0.1S500
G1 X-5.4S0
G1 X-0.1S500
G1 X-2.7S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-5.3S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-0.019S0
G1 X3.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X4.4S0
G1 X0.1S500
G1 X6.5S0
G1 X0.1S500
G1 X8.4S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X5.3S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X3.7S0
G1 X0.1S500
G1 X0.019S0
G1 X-2.1Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-3.8S0
G1 X-0.1S500
G1 X-3.7S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-3.8S0
G1 X-0.1S500
G1 X-9.6S0
G1 X-0.1S500
G1 X-3.9S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.019S0
G1 X5.2Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X7.2S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X17.5S0
G1 X0.1S500
G1 X5.1S0
G1 X0.1S500
G1 X0.019S0
G1 X0.9Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-6.1S0
G1 X-0.1S500
G1 X-4.1S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-8.2S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-3.7S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.019S0
G1 X1.3Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X10.7S0
G1 X0.1S500
G1 X3.8S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X11.6S0
G1 X0.1S500
G1 X3.9S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X0.019S0
G1 X0.6Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-4S0
G1 X-0.1S500
G1 X-9.3S0
G1 X-0.1S500
G1 X-6.1S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-6.7S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-0.019S0
G1 X3.2Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X3.5S0
G1 X0.1S500
G1 X4S0
G1 X0.1S500
G1 X20S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X3.8S0
G1 X0.1S500
G1 X4.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X0.019S0
G1 X-0.6Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-11.6S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-4.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-2.9S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-7.2S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-3.4S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-3.5S0
G1 X-0.1S500
G1 X-0.019S0
G1 X0.3Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X2.9S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X7S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X4S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X6.4S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X0.019S0
G1 X4.8Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-5.1S0
G1 X-0.1S500
G1 X-4.5S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-3.5S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-4.5S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-5S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-0.9Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X10.2S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X4.4S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X7.8S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X3.1S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X6.7S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.019S0
G1 X-1.8Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-10.5S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-10.4S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-0.019S0
G1 X3.4Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X4.8S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X9.9S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X8.4S0
G1 X0.1S500
G1 X2.6S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S5G1 X4.8S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.019S0
G1 X-2.1Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-9.5S0
G1 X-0.1S500
G1 X-2.9S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-8.9S0
G1 X-0.1S500
G1 X-5S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-3.8S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-4.1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X6.5S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X10.5S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X4.9S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X5.8S0
G1 X0.1S500
G1 X0.019S0
G1 X-8.1Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-4S0
G1 X-0.1S500
G1 X-5.2S0
G1 X-0.1S500
G1 X-6.3S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-4.3S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-0.019S0
G1 X1.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X10.2S0
G1 X0.1S500
G1 X7.8S0
G1 X0.1S500
G1 X5.1S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X11.9S0
G1 X0.1S500
G1 X3.3S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X0.019S0
G1 X0.6Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-8.7S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-4.2S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-2.9S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-4.3S0
G1 X-0.1S500
G1 X-5.4S0
G1 X-0.1S500
G1 X-2.7S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-5.3S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-0.019S0
G1 X3.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X4.4S0
G1 X0.1S500
G1 X6.5S0
G1 X0.1S500
G1 X8.4S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X5.3S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X3.7S0
G1 X0.1S500
G1 X0.019S0
G1 X-2.1Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-3.8S0
G1 X-0.1S500
G1 X-3.7S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-3.8S0
G1 X-0.1S500
G1 X-9.6S0
G1 X-0.1S500
G1 X-3.9S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.019S0
G1 X5.2Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X7.2S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X17.5S0
G1 X0.1S500
G1 X5.1S0
G1 X0.1S500
G1 X0.019S0
G1 X0.9Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-6.1S0
G1 X-0.1S500
G1 X-4.1S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-8.2S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-3.7S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.019S0
G1 X1.3Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X10.7S0
G1 X0.1S500
G1 X3.8S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X11.6S0
G1 X0.1S500
G1 X3.9S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X0.019S0
G1 X0.6Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-4S0
G1 X-0.1S500
G1 X-9.3S0
G1 X-0.1S500
G1 X-6.1S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-6.7S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-0.019S0
G1 X3.2Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X3.5S0
G1 X0.1S500
G1 X4S0
G1 X0.1S500
G1 X20S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X3.8S0
G1 X0.1S500
G1 X4.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X0.019S0
G1 X-0.6Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-11.6S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-4.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-2.9S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-7.2S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-3.4S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-3.5S0
G1 X-0.1S500
G1 X-0.019S0
G1 X0.3Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X2.9S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X7S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X4S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X6.4S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X0.019S0
G1 X4.8Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-5.1S0
G1 X-0.1S500
G1 X-4.5S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-3.5S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-4.5S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-5S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-0.9Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X10.2S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X4.4S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X7.8S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X3.1S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X6.7S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.019S0
G1 X-1.8Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-10.5S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-10.4S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-0.019S0
G1 X3.4Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X4.8S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X9.9S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X8.4S0
G1 X0.1S500
G1 X2.6S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S5G1 X4.8S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.019S0
G1 X-2.1Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-9.5S0
G1 X-0.1S500
G1 X-2.9S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-8.9S0
G1 X-0.1S500
G1 X-5S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-3.8S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-4.1Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X6.5S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X10.5S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.5S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X4.9S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X3.6S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X5.8S0
G1 X0.1S500
G1 X0.019S0
G1 X-8.1Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-4S0
G1 X-0.1S500
G1 X-5.2S0
G1 X-0.1S500
G1 X-6.3S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-4.3S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-2.6S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-0.019S0
G1 X1.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X10.2S0
G1 X0.1S500
G1 X7.8S0
G1 X0.1S500
G1 X5.1S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X11.9S0
G1 X0.1S500
G1 X3.3S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X0.019S0
G1 X0.6Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-8.7S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-4.2S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-2.9S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-4.3S0
G1 X-0.1S500
G1 X-5.4S0
G1 X-0.1S500
G1 X-2.7S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-5.3S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-0.019S0
G1 X3.7Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X4.4S0
G1 X0.1S500
G1 X6.5S0
G1 X0.1S500
G1 X8.4S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X5.3S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X3.7S0
G1 X0.1S500
G1 X0.019S0
G1 X-2.1Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-3.8S0
G1 X-0.1S500
G1 X-3.7S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-2.8S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-3.8S0
G1 X-0.1S500
G1 X-9.6S0
G1 X-0.1S500
G1 X-3.9S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-0.019S0
G1 X5.2Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X7.2S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X17.5S0
G1 X0.1S500
G1 X5.1S0
G1 X0.1S500
G1 X0.019S0
G1 X0.9Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-6.1S0
G1 X-0.1S500
G1 X-4.1S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-2.3S0
G1 X-0.1S500
G1 X-8.2S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-2S0
G1 X-0.1S500
G1 X-2.1S0
G1 X-0.1S500
G1 X-3.7S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-0.019S0
G1 X1.3Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X10.7S0
G1 X0.1S500
G1 X3.8S0
G1 X0.1S500
G1 X2.5S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X2.1S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X11.6S0
G1 X0.1S500
G1 X3.9S0
G1 X0.1S500
G1 X2.2S0
G1 X0.1S500
G1 X0.019S0
G1 X0.6Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-1S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-3.2S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-0.8S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-4S0
G1 X-0.1S500
G1 X-9.3S0
G1 X-0.1S500
G1 X-6.1S0
G1 X-0.1S500
G1 X-3.6S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-6.7S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-0.019S0
G1 X3.2Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X3.5S0
G1 X0.1S500
G1 X4S0
G1 X0.1S500
G1 X20S0
G1 X0.1S500
G1 X1S0
G1 X0.1S500
G1 X3.8S0
G1 X0.1S500
G1 X4.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X0.019S0
G1 X-0.6Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-11.6S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-0.6S0
G1 X-0.1S500
G1 X-4.4S0
G1 X-0.1S500
G1 X-0.3S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-2.9S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-7.2S0
G1 X-0.1S500
G1 X-2.2S0
G1 X-0.1S500
G1 X-3.4S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-3.5S0
G1 X-0.1S500
G1 X-0.019S0
G1 X0.3Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X2.9S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X7S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X0.7S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X1.3S0
G1 X0.1S500
G1 X4S0
G1 X0.1S500
G1 X2S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X1.4S0
G1 X0.1S500
G1 X6.4S0
G1 X0.1S500
G1 X2.4S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
G1 X0.019S0
G1 X4.8Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-5.1S0
G1 X-0.1S500
G1 X-4.5S0
G1 X-0.1S500
G1 X-2.5S0
G1 X-0.1S500
G1 X-3.5S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-4.5S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-0.7S0
G1 X-0.1S500
G1 X-1.2S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-5S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-0.5S0
G1 X-0.1S500
G1 X-0.019S0
G1 X-0.9Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.3S0
G1 X0.1S500
G1 X10.2S0
G1 X0.1S500
G1 X1.1S0
G1 X0.1S500
G1 X2.3S0
G1 X0.1S500
G1 X4.4S0
G1 X0.1S500
G1 X2.7S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X7.8S0
G1 X0.1S500
G1 X1.7S0
G1 X0.1S500
G1 X3.1S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X0.8S0
G1 X0.1S500
G1 X6.7S0
G1 X0.1S500
G1 X0.4S0
G1 X0.1S500
G1 X0.019S0
G1 X-1.8Y-0.1S0
G1 X-0.019S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-5.8S0
G1 X-0.1S500
G1 X-1.6S0
G1 X-0.1S500
G1 X-1.1S0
G1 X-0.1S500
G1 X-0.9S0
G1 X-0.1S500
G1 X-10.5S0
G1 X-0.1S500
G1 X-1.4S0
G1 X-0.1S500
G1 X-1.3S0
G1 X-0.1S500
G1 X-1.9S0
G1 X-0.1S500
G1 X-1.8S0
G1 X-0.1S500
G1 X-1.5S0
G1 X-0.1S500
G1 X-10.4S0
G1 X-0.1S500
G1 X-0.4S0
G1 X-0.1S500
G1 X-1.7S0
G1 X-0.1S500
G1 X-0.019S0
G1 X3.4Y-0.1S0
G1 X0.019S0
G1 X0.1S500
G1 X0.5S0
G1 X0.1S500
G1 X2.8S0
G1 X0.1S500
G1 X4.8S0
G1 X0.1S500
G1 X1.8S0
G1 X0.1S500
G1 X9.9S0
G1 X0.1S500
G1 X1.2S0
G1 X0.1S500
G1 X8.4S0
G1 X0.1S500
G1 X2.6S0
G1 X0.1S500
G1 X0.6S0
G1 X0.1S500
G1 X0.9S0
G1 X0.1S500
Note that you can upload the file as a whole to the forum by dragging and dropping. As long as it’s an accepted format such as .txt this will work.
I don’t see anything inherently wrong in the gcode content. That would imply that for some reason your laser doesn’t like what it’s receiving.
Can you take a screenshot of Edit->Device Settings and post here?
Your file is set to “Current Position” mode. Is that intentional? Do you understand how Current Position mode works?
no but yes i tried all options for positions
sorry for long reply for some reason i had to wait 24 hours tell i could reply
It looks like you have some Device Configuration issues. The easiest way to address will be to recreate the device.
- Push “Devices” button in Laser window and then delete your current device.
- Download this file and import as a new device in Devices window:
https://support.xtool.com/hc/article_attachments/6567075470999/xTool-D1-V2.lbdev - Then shutoff your machine and move the laser head to top-left corner of the machine
- Start machine
- In LightBurn set “Start From” to Absolute Coords
- Retest your job.
Note: Make sure that the port field is set to COM5 in case it defaults to “(Choose)” after your recreate the device.
