I have updated your account, so you should not have this limit going forward.
thank you very much
it did not work
Can you send a full screenshot of LightBurn and updated Device Settings view?
Was there any change in behavior at all?
Can you restart the laser and test again? Then capture all content of Console from power-on and paste here.
some of it actually GOT engraved only the name though
Waiting for connectionâŚ
ok
ok
ok
[XTool D1:ver 40.30.003.01 B9]
ok
MPos:0.000000,0.000000,0.000000,0.000000
Starting stream
Stream completed in 0:00
[MSG:Pgm End]
Starting stream
Layer C00
M8 N4
Layer C00
M8 N4
Guru Meditation Error: Core 1 panicâed (IntegerDivideByZero). Exception was unhandled.
Core 1 register dump:
PC : 0x40085038 PS : 0x00060e31 A0 : 0x80085e66 A1 : 0x3ffc0090
A2 : 0x00002710 A3 : 0x00000000 A4 : 0x00000000 A5 : 0x00000000
A6 : 0x3ffbac14 A7 : 0x3ffb844c A8 : 0x8008502f A9 : 0x3ffc0070
A10 : 0x3ffbac14 A11 : 0x00000000 A12 : 0xfffffc01 A13 : 0x000003ff
A14 : 0x7ff00000 A15 : 0x3ff00000 SAR : 0x0000000d EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000 LBEG : 0x400029ac LEND : 0x400029cb LCOUNT : 0x00000000
Core 1 was running in ISR context:
EPC1 : 0x40085038 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008d7a4
ELF file SHA256: 0000000000000000
Backtrace: 0x40085038:0x3ffc0090 0x40085e63:0x3ffc00c0 0x40085efd:0x3ffc00e0 0x400866b9:0x3ffc0100 0x4008d019:0x3ffc0120 0x4008e6e5:0x3ffb1f70 0x400d2c32:0x3ffb1f90 0x400e48e5:0x3ffb1fb0 0x400909e6:0x3ffb1fd0
RebootingâŚ
f~f~
Job halted
Stream completed in 0:50
ok
I think itâs fundamentally working but your controller is now crashing.
Can you send a screenshot of Edit->Device Settings? You sent the Devices window previously.
This issue may be difficult to troubleshoot as there are not a lot of success stories. After you send the screenshot we can discuss options.
where is device the settings?
Go to Edit menu. Then select Device Settings.
Yes. Thatâs it. Looks fine.
So the times Iâve seen controller crashing on D1 you can try:
- Different USB port on your computer
- Different high quality USB cable
- Consider updating to the latest beta firmware:
Notification of the Update of Beta Versions xTool D1 Firmware V005 â xTool
One user had to use a different computer in order to address the issue but hopefully it wonât come to that.
I donât have another USB cable but I did everything else
it did not work
Can you describe this? Is it exactly the same? Did the firmware apply correctly?
yea it framed correctly did the name just not the other thing
Can you confirm the firmware version with $I
in Console?
$I
ok
ok
That looks like the same firmware you had been using before. How did you try to apply the newer firmware?
i think so
It was not updated so I did
still nothing
proof
$I
ok
ok
Umm⌠Your proof is the same versionâŚ
itâs weird i installed the new stuff
or at least it says I did.
