New user, so forgive if the question has been covered - a search didn’t turn up anything related.
I’m using a S03XL, have been using it for quite some time without difficulty.
I have upgraded to a SuperGerbil control board. The software is 1.1f, ported to ARM.
This supports A and B axis, which I am not currently using.
I’ve been using it just fine with UGS and other senders
Where I’m having trouble
I can connect to the controller and jog. That seems ok.
clicking “get position” never returns any data in the display.
After homing, no commands via the console work at all. $$, $X, $, ? do not return responses.
I suspect that this is related to the additional information returned in the status messages for the additional axis (ie. 5 axis instead of 3) . GRBL doesn’t have a means to manipulate the report format, so I’m not sure where to go from here.
Any easy ways to get through this?
example:
Waiting for connection…
ok
Homing
ok
<Idle|MPos:0.000,0.000,0.000,0.000,0.000|Bf:15,254|FS:0,0|Pn:PAB|WCO:-219.988,-370.000,-90.000,0.000,0.000>
$X
I’ll have to add code to handle the additional axis reports - I’ve never seen that before, and it’s likely the code doesn’t handle it.
Having said that, it shouldn’t affect whether you get a reply back from $$, $#, or ?, unless the extra state is confusing my parser and resulting in a locked state somehow. I notice that there’s no ‘ok’ after the status report. I believe normal GRBL does this, and LightBurn expects it. That might actually be the problem.
Strange that there is no ok acknowledgement since this part of the code has not much changed from the Grbl arduino part. Only the N=3 is now N=5 because of 5 axis. The change in firmware can be achieved easily and I am thinking $10 can be modified to include the option to turn off the A and B axis reports.
There are some 1.1f changes in it - among other things (ie. additional axis) - I’m not sure the extent.
I’ve actually tried to recompile a couple times over the past few months, and have not been successful yet, but have been trying to do so a little round-about… The atollic compiler appears to be the only one that works right, the STMcube compiler says it can import the old projects, but hasn’t worked for me. I’ve got to set up a linux vm to use atollic, and just haven’t done so yet.
GRBL is at 1.1h, which has some additional fixes around doors and coolant that are probably not too interesting here.
I’ve logged it as a bug and set it high priority, but I have a few vendor needs ahead of it, so it might or might not make it into this release, depending on workload.
I’ve looked at the logic in this code, and I think it’s the missing OK response that’s the root of all of this. The code already handles varying counts of values, because GRBL can be compiled as 3 axis or 4 axis easily, so I generalized it to handle “any”. The missing OK would mean LightBurn was still waiting for GRBL to finish responding, and since it never gets the completion acknowledgement, it never returns your result.
The logic that parses out the MPos value does this:
Take everything between the <>'s, split it up into chunks using | as the delimiter
This will give you a list containing (Idle), (MPos:0.000:0.0,.0,0.0,0.0), (Bf:15,254), … etc
Each one of the entries above is parsed looking for MPos: or WPos: as a prefix. If found, go to the next step
The MPos: or WPos: prefix is removed, and the values are split by commas, which would give us a list containing (0.0), (0.0), (0.0), (0.0), … etc
If the list contains more than 1 value, it’s considered valid and pulls out X & Y. If it contains more than 2 values, it pulls the 3rd as Z. If it contains more than 3 values, it pulls the 4th as A.
That’s all a fair statement and all… but I don’t think the “ok” is the basic problem - I DO get “ok” for everything I’ve tried on UGS. Everything in this case seems to be working fine until this point- I can issue commands, it only break when I get to this point of asking for “get position” - then things are broken. I understand what you’re saying, and you know the code better than anyone, but something isn’t working right in this particular case.
That’ll be the problem. Paul’s custom version of GRBL appears to be eating the ok at the end of <Idle|MPos:0.000,0.000,0.000,0.000,0.000|Bf:15,253|FS:0,0|Pn:PAB>
If I don’t get an ok, I keep waiting, assuming more characters are coming. I could make it terminate waiting on a carriage return, but I worry that will break something else. This works for every other controller.
