Dim Light When Framing
I have an Omtech MOPA 60W Lightburn 1.4.01. When framing, I can’t see the area in order to line up the part. When I turn out the lights, I can see the framing but still cannot line up the object properly. I have red forums and I don’t know what else to do. Please help.
I have a similar animal, only difference is mine says Cloud Ray instead of OMTech.
As far as I know the visible light led intensity is not adjustable… I’d like to turn mine down… also that this light comes from the laser source.
That you can see it in dim light is also questionable…
How old is this machine? If possible, does it work correctly with EZCad2?
This is the JPT M7 MOPA laser source manual if that’s what’s in your box.
If it’s new and have the same symptoms with EZCad2, I’d have a talk with OMTech.
Good luck
