Here you go. Enjoy! Made with LightBurn (project file attached). Riser and cover is made from .12" (3mm) acrylic. Base is made from ½" (13mm) acrylic.
Display_Box_With_Risers.lbrn (196.2 KB)
I also REALLY WISH LightBurn had such a utility built in to it
I always use:
https://www.festi.info/boxes.py/
Thank you for the link, it will save us some time.
Sasquatch
The SciGrip is certainly THE BEST for acrylic bonding. I prefer the viscosity and set time of “16”. It is slightly more fluid than a gel. Despite it’s thicker formulation, it still performs very well for capillary application.
Syringes - that will be determined by where you live. Cheapest is to just use plain ole medical grade supply. With Sci Grip 16, I think an 18 gauge needle is ideal. To fill the syringe, remove the needle and vacuum the adhesive. Then clean up the syringe with a paper towel and put the needle back on. You can always just buy Industrial Syringes with 18 Gauge Blunt Tip Needles as well:
Shintop 10pcs 5ml Syringe with 18Ga 1.5 Inches Blunt Tip Needles for Experiments, Industrial Use
by Shintop
Learn more: https://www.amazon.com/dp/B074M4RB86/ref=cm_sw_em_r_mt_dp_U_fOdvEbZ3ND6M0
SCIGRIP 16 Acrylic Cement, Low-VOC, Medium bodied, 1 Pint Can with Screw-on Cap, Clear
by Amazon.com
Learn more: https://www.amazon.com/dp/B005ZH31W2/ref=cm_sw_em_r_mt_dp_U_gBdvEbA252Y90
@Stroonzo I appreciate the information and techniques you have shared with us as well as the clarification on the tools and supplies you prefer .
Cheers and good luck in your business ventures.
Sas
