Distorted engraved offset lettering lettering
Hi
I need help to solve this engraving issue (see pic).
checked all hardware issues re beams, belt tensions and tightness of screws etc.
Thanks
Reggie
How are you connecting to your engraver?
…this could be an EM noise problem.
If you repeat the job do the error lines or indented line match?
Hi JJ
I’m connected to the engraver via a USB cable.
The miss aligned engravings are repeated almost exactly.
When trying engraving again yesterday the first test was good. Then second and third test miss aligned.
Tim
Your symptoms seem similar to what was going on in this Topic. In the end it was a bad communication issue due to the USB cable. Possible electrical noise. Resolved by using ethernet. I suspect a better shielded cable might have also worked.
