Draw thicker lines
Is there a way to set the thickness of lines that are being drawn? Especially on the display screen. When I draw a square, I can barely see them.
There isn’t, no - making them thicker than a pixel would slow the rendering down a lot. Do you have that layer enabled? If not, that will “ghost” the lines, which would make them harder to see.
I am so new to lightburn. How do I tell if the later is enabled?
Randy
In the list of cuts in the upper right, there’s a pair of check boxes next to each color you’re using. One of them is “output” (send to the laser) and the other is “show”. Make sure the “output” box is checked. You can also select your art and change the color by clicking a different color entry on the bottom. Some of them are kind of faint.
