Los trabajos de líneas simples los hace con doble línea en cualquier superficie
Simple line work is done with double lines on any surface.
Mi creality falcon 2, 22 w, graba desde hace un mes con doble línea. Uso Lightburn. Dibujos de líneas simples los graba con líneas dobles en cualquier superficie utilizada. Necesito solucionar este error. Calibré el lente, lo limpié, ajusté tuercas. Pero sigue grabando igual
Can you provide images and the Lightburn file?
mate ink corazón grueso.lbrn2 (170.2 KB)
Which mode do you use for this object? Do you use a rotary or chuck? If using a rotary, you need to use fill mode and scan along the object. If you use line mode, there is too much turning of the object which will lead to displacement.
I do not have either of my machines set up for a rotary, so I was not able to see if I could duplicate your output. However, I did examine your Lightburn file in detail, and made some corrections to it.
I have made changes in the attached file. The run time in Preview went from 15+ minutes to about 6 minutes. Run a test on the back side of one you tried and let us know the results.
mate ink corazón grueso-2.lbrn2 (170.3 KB)
