Elegoo Phecda 10W custom firmware upload
I bought Elegoo Phecda 10w machine. But $3-Step Direction Invert settings are not saved in the device’s eeprom. I don’t want to run a macro every time with Ligtburn macro. I want to grbl settings permanently within the device.
There is an MKS DLC32 card in the machine. Can I install custom grbl 1.1 firmware on my machine? If I install this firmware, will I be able to use the LCD screen etc.?
Yes. The best option in my opinion is FluidNC in this case.
Probably not. Those extra functions a usually propritary, so FluidNC doesn’t support them. You can try the official firmware from MKS which can control a display, if they didn’t change the connectors, that might work. But the functions on the display are then derived from the MKS firmware and might be different.
I tried mks software. The machine did not work.
I installed the original firmware again.
Now I want to try FluidNC. But there are GPIO settings in the config file. I don’t have a diagram of which motor is connected to which pin. Do I need to detect individual pins on the card?
If it is a MKS DLC32 board, there should be samples. But if it is only a board using an ESP32 chip (then it’s no DCL32), then you would have to find out all pins at your own, correct.
This board DLC32. Some changes have been made…Pins are very difficult to find. 3-4 layers pcb
The whole board layout and schematics is on github…?
Yes, of the DLC32, but he has a Elegoo Phecda with some sort of clone/derivate, as far as I understood.
It would seem rather odd, to take an open source board and hack it… but it wouldn’t totally surprise me. As far as I knew it was GNU…
Maybe a photo?
This is my DLC32…
At least Sculpfun did, with their first designs. :slight_smile: The 8bit board they had was nearly a complete clone of the DLC and the first 32bit board of the S10 model was (internally) pin-compatible to the DLC32. Though they changed the layout quite a bit to stay compatible to the older 8 bit boards conntector-wise.
Didn’t know there was any external signal differences between 8 bit and 32 bit boards…?
which hardware?
No, I meant the position and types of the connectors stayed the same. You can swap the boards and don’t need to reposition any connectors. They are all at the same location. Here is an example of the DLC, the first generation Sculpfun boards and the DLC32, which has a different layout. (I listed most Sculpfun boards here, if anyone is interested :wink: )
Should be printed on your board, in doubt, select the latest.
I reviewed the Elegoo Phecda chart. It is not the same as MKS. Some pins are different. I detected them.
However, the most important difference is the TFT touchscreen display.
Elegoo Phecda communicates with the ESP32 on the other TFT screen via I2C.
In MKS, a small LCD screen is connected directly to the ESP pins on the motherboard via SPI.
I emailed Elegoo. They sent me schematics. But as I mentioned in the diagram, the TFT screen is not like MKS. It connects via I2c. Pins are different.
Then I asked for source code. But they did not give it.
Phecda Shematic PINS
MKS DLC32 V2.1 PINS
FluidNC MKS DLC32 Config
board: MKS-DLC32
meta: 2022-12-27 by Tong
kinematics:
  Cartesian:
stepping:
  engine: I2S_STATIC
#Static only, Stream Produces a second "ghost line" when doing engraving/Filling
  idle_ms: 254
  pulse_us: 6
  dir_delay_us: 10
  disable_delay_us: 0
axes:
  shared_stepper_disable_pin: I2SO.0
  x:
    steps_per_mm: 157.500
    max_rate_mm_per_min: 5000.000
    acceleration_mm_per_sec2: 1000.000
    max_travel_mm: 313.000
    soft_limits: true
    homing:
      cycle: 1
      positive_direction: false
      mpos_mm: 0.000
      feed_mm_per_min: 300.000
      seek_mm_per_min: 6000.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    motor0:
      limit_neg_pin: gpio.36
      hard_limits: false
      pulloff_mm: 1.000
      stepstick:
        step_pin: I2SO.1
        direction_pin: I2SO.2:low
  y:
    max_travel_mm: 230.000
    soft_limits: true
    homing:
      cycle: 1
      mpos_mm: 0.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    motor0:
      limit_neg_pin: gpio.35
      hard_limits: false
      pulloff_mm: 1.000
      stepstick:
        step_pin: I2SO.5
        direction_pin: I2SO.6:high
  z:
    steps_per_mm: 157.750
    max_rate_mm_per_min: 12000.000
    acceleration_mm_per_sec2: 500.000
    max_travel_mm: 80.000
    soft_limits: true
    homing:
      cycle: 0
      mpos_mm: 0.000
      seek_mm_per_min: 1000.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    motor0:
      limit_neg_pin: gpio.34
      hard_limits: false
      pulloff_mm: 1.000
      stepstick:
        step_pin: I2SO.3
        direction_pin: I2SO.4
i2so:
  bck_pin: gpio.16
  data_pin: gpio.21
  ws_pin: gpio.17
spi:
  miso_pin: gpio.12
  mosi_pin: gpio.13
  sck_pin: gpio.14
sdcard:
  cs_pin: gpio.15
  card_detect_pin: gpio.39
control:
  safety_door_pin: NO_PIN
  reset_pin: NO_PIN
  feed_hold_pin: NO_PIN
  cycle_start_pin: NO_PIN
  macro0_pin: gpio.33:low:pu
  macro1_pin: NO_PIN
  macro2_pin: NO_PIN
  macro3_pin: NO_PIN
macros:
  startup_line0:
  startup_line1:
  macro0: $SD/Run=lasertest.gcode
  macro1: $SD/Run=home.gcode
  #These are examples
  macro2:
  macro3:
coolant:
  flood_pin: NO_PIN
  mist_pin: NO_PIN
  delay_ms: 0
probe:
  pin: gpio.22
  check_mode_start: true
Laser:
  pwm_hz: 5000
#For software PWM control on K40, IN on TTL connection, G next to IN to G on TTL. No need for Enable
  output_pin: gpio.32
  enable_pin: NO_PIN
  disable_with_s0: false
  s0_with_disable: false
  tool_num: 0
  speed_map: 0=7.500% 2200=100.000%
# 165=1mA (not enough to fire), 880=9mA 2200=16mA
# Set your own MAX and Minimum,
# Change max until desired MAX mA on gauge
# Change min until laser just before laser fires.
user_outputs:
  analog0_pin: NO_PIN
  analog1_pin: NO_PIN
  analog2_pin: NO_PIN
  analog3_pin: NO_PIN
  analog0_hz: 5000
  analog1_hz: 5000
  analog2_hz: 5000
  analog3_hz: 5000
  digital0_pin: NO_PIN
  digital1_pin: NO_PIN
  digital2_pin: NO_PIN
  digital3_pin: NO_PIN
start:
  must_home: true
# 5,18,19,22,23,25,26,27,32,33,39,I2SO.7
# SDA 0 / SCL 4
Phecda not use I2SO…
MKS use I2SO
stepping:
engine: I2S_STATIC ???
No, it looks like they directly drive the steppers, no additional controller integrated. try:
engine: RMT
For the motors, don’t use I2SO.xyz but gpio.xyz for each pin.
TMC2209 was used as the driver. (elegoo phecda)
I couldn’t find the step/pulse settings in FluidNC.
Example RMT config
stepping:
  engine: RMT
  idle_ms: 255
  pulse_us: 2
  dir_delay_us: 1
  disable_delay_us: 0
axes:
  shared_stepper_disable_pin: NO_PIN
  x:
    steps_per_mm: 800.000
    acceleration_mm_per_sec2: 100.000
    max_travel_mm: 300.000
    soft_limits: false
    homing:
      cycle: 2
      mpos_mm: 150.000
      feed_mm_per_min: 100.000
      seek_mm_per_min: 200.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    motor0:
      limit_neg_pin: NO_PIN
      limit_pos_pin: NO_PIN
      limit_all_pin: NO_PIN
      hard_limits: false
      pulloff_mm: 1.000
      tmc_2130:
        cs_pin: gpio.17
        spi_index: 1
        r_sense_ohms: 0.110
        run_amps: 0.750
        hold_amps: 0.750
        microsteps: 16
        stallguard: 0
        stallguard_debug: false
        toff_disable: 0
        toff_stealthchop: 5
        toff_coolstep: 3
        run_mode: CoolStep
        homing_mode: CoolStep
        use_enable: true
        step_pin: gpio.12
        direction_pin: gpio.14
        disable_pin: NO_PIN
  y:
    soft_limits: false
    homing:
      cycle: 2
      mpos_mm: 150.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    motor0:
      hard_limits: false
      pulloff_mm: 1.000
      tmc_2130:
        spi_index: 2
        r_sense_ohms: 0.110
        run_amps: 0.750
        hold_amps: 0.750
        microsteps: 16
        stallguard: 0
        toff_disable: 0
        toff_stealthchop: 5
        toff_coolstep: 3
        run_mode: CoolStep
        use_enable: true
        step_pin: gpio.27
        direction_pin: gpio.26
        disable_pin: NO_PIN
  z:
    soft_limits: false
    homing:
      cycle: 2
      mpos_mm: 150.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    motor0:
      hard_limits: false
      pulloff_mm: 1.000
      tmc_2130:
        spi_index: 3
        r_sense_ohms: 0.110
        run_amps: 0.750
        hold_amps: 0.750
        microsteps: 16
        stallguard: 0
        toff_disable: 0
        toff_stealthchop: 5
        toff_coolstep: 3
        run_mode: CoolStep
        use_enable: true
        step_pin: gpio.15
        disable_pin: NO_PIN
  a:
    soft_limits: false
    homing:
      cycle: 2
      mpos_mm: 150.000
      settle_ms: 500
      seek_scaler: 1.100
      feed_scaler: 1.100
    motor0:
      hard_limits: false
      pulloff_mm: 1.000
      tmc_2130:
        spi_index: 4
        r_sense_ohms: 0.110
        run_amps: 0.750
        hold_amps: 0.750
        microsteps: 16
        stallguard: 0
        toff_disable: 0
        toff_stealthchop: 5
        toff_coolstep: 3
        run_mode: CoolStep
        use_enable: true
        step_pin: gpio.33
        direction_pin: gpio.32
        disable_pin: NO_PIN
spi:
  miso_pin: gpio.19
  mosi_pin: gpio.23
  sck_pin: gpio.18
sdcard:
  card_detect_pin: NO_PIN
  cs_pin: gpio.5
probe:
  pin: NO_PIN
macros:
  startup_line0:
  startup_line1:
  macro0:
  macro1:
  macro2:
  macro3:
start:
  must_home: false
You don’t need to check that extra motor diagram, just the one with the ESP. There, the IO pins are listed (x_step is IO25 (if I can decipher correctly) etc. Though, I don’t see a y_dir pin listed. Weird. Those Chinese diagrams are the hell :slight_smile: This can’t be true.
Looks like IO5/29.
Ah, true. Maybe I should have my eyes tested sometime. :slight_smile: Or the lasers killed too many retina cells :wink:
