Engrave - Fill - Scan Vector lines
Hello,
I want to engrave a vector object, for example a circle, but instead of using the “Line” option where the laser will just follows the specified path, I want to “scan it” or engrave the circle line like the “Fill” option but only marking the circle delimiter.
Note that I don’t want to fill all the circle inside but “scan” only the line that limits the circle.
What is the best way to accomplish this?
Thanks,
The simplest way is to use the offset tool to make another circle around the first one, on the same layer, then set that layer to fill. It will fill the area between them.
Similar to this:
Hi guys. Maybe someone can find a minute or already have a video lesson for beginners. I became unemployed and I was bored sitting all day. I decided to learn something new and my choice fell on lightburn. Who can help give the answer. Thank!
There are several LightBurn learning videos available on our site and also on Youtube. Here is a good place to start:
There is a FAQ section as well: https://forum.lightburnsoftware.com/c/faq
You can also search this forum for “Tips and Tricks” or visit:
