How do I invert (negate) a vector engraving?
If you want to invert a vector engraving (Fill layer) you need to add an outline to it. Think about what happens when you scan a circle, compared to the letter ‘O’. The inner ring of the O toggles the fill. If you add another shape (like a square) outside it, it negates the whole thing:
And a slightly different example, this time done by changing the outer line around the design to a ‘Line’, instead of leaving it as part of the Fill layer:
In the case above, the design already had the double outline shown in the first picture. In many cases, that won’t exist, so you can add an extra outline using the ‘Offset’ tool in LightBurn to offset the outer-most curve (or curves) around the design. Using the O shapes above again, the result would look something like this:
How to reverse the burn?
Rubber stamp created
Fill and how it really works?
How do I make a rectangle or circle with a 3mm border
Engraving around an object
Getting vector shapes to fill+line properly (AI> SVG>Lightburn)
Importing file from CorelDRAW
Text up front on picture engrave
Engrave - Fill - Scan Vector lines
Selective filling?
White (not engraved) text on solid color background
Inverting what is lasered
Invert Engrave or Fill
Guidance please
Vector Image not complete filling
How to not fill a certain area in side of a shape
Query about text having gaps filled in
Fill between two objects
Engraving or making raised text using LightBurn Text
Overlapping objects turn White?
I'm trying to fill around text
Knock out letter and shapes
Variable Text with Emboss/Difference?
Burning/engraving inverted text/logo
How to fill a surface with engraver & penholder?
Inverting an Image
Confused by output of Inverted Image
I wanto to fill in a circle, but not completely
Negative image toggle broken?
Two circles fill in between but but leave letters in that area
How do I create an unengraved shape within an engraved shape?
Text not showing up on preview
“image optimization”
How do I create a negative of an svg file
Help..I'm new and learning
Setting fill in lines
Fill is reversed - want to do an outline but filling my whole shape
Short time listener, first time caller
Preview not same as design 9.16
Import gimp layers?
How to get inverse fill to follow outline without waste
Resize image and multiple images per row/columns
Putting text in a filled in shape
Rubber band frame issues
Graphic Issue - Complete Fill Issue
Output QRCode negative
Fill+Line question
The fill covers everything
Fill of nested curves
How to change what part of copied image gets engraved
Reverse Burn Logo
How do I set a logo to reverse engrave? I want the background to engrave, not the logo
Crating square around the logo
Question about engraving cups
Invert Funktion
Newbie has questions about stars on flag
Fill and line layers
Rubber stamp design
Possible invert question. But not sure
Box lettering filling the area in the R
HELP how to tell the laser to cut inverted image
Inverting image
Outline and Fill Question
Fill all shapes at once ignoring half of artwork
Avoid a fill in a box 3" x 3"
How to invert engraving?!
Eyes are fully black
Imported SVG does not show text and graphics when using the fill setting
Noob question, prob something easy I'm missing - fill in a letter
Lined shapes inside a fill area
Invert black and white SVG files
How to fill a specific area
How to fill all except interior objects
Fill part of image
Kreisring gravieren - Engrave circular ring
Best method to import a QR code?
Engraving help!
Bringing a object to the front
Setting a section to *not* fill
Filling around other details
Switching what gets burned out or rastered
Try to make a fill but it is not what i like to have
Fill box with raised lettering
Cost of licensing
Prospective new laser machine utilising LightBurn with Coreldraw
Background image
Text and Fill Issues
Here is another example on this topic to help illustrate how LightBurn determines which object shapes to fill.
