Output QRCode negative
Hello!
My first post here…
I´m trying to etch qrcodes in anodized aluminun and some smartphones doesn´t read them.
Looking around I saw that it´s better to have a darker foreground.
So I followed this example:
https://forum.lightburnsoftware.com/t/how-do-i-invert-negate-a-vector-engraving/594
But Lightburn showed this warning:
Clipboard01
What is the correct way to output qrcode negative?
Thanks.
Eduardo
What 1 shape wasn’t closed?
If I make a QR in LB and then draw a square around it on the same layer it inverts just fine.
This notification is identifying an Open Shape set to Fill, so this is a different issue that will need to be addressed. What is shown if you select ‘Show me’ button? :slight_smile:
As for inverting the QR Code output. I simply selected the QR Code, then add an outward Offset of 0.5mm to it on the same fill layer.
@Hank,
this is the shape:
One of the little squares the QR generator spit out isn’t closed? That’s interesting. Sounds like a question for Oz & co.
Can you close it and carry on?
@Hank,
yes, but I am afraid that the scanners are using some error correction to decode de qrcode.
@Rick,
when a use the offset the my qrcode isn´t inside a square like yours:
3
Turn the Offset from both inside and outside to only outside and a small amount. You should get one outline produced. You can practice with a simple square to see what I am showing. I have the resulting Offset shapes set to red to see easier.
Or, you can simply add a square as @Hank suggests as well. :wink:
