Engraving Alignment and origin issue
Hi all,
I’m not sure if this is a hardware or software issue, but I’ve seen this on both RD Works and Lightburn, so my guess is hardware (or a controller setting).
I have an issue when cutting shapes (ornaments in this case), where I’m doing a long-ish engraving of multiple ornaments, then I do a cutout of the ornaments. Many times, some of the ornaments are not aligned properly (engraving to cut). I’ve also seen this with the cut and fill function.
Tonight, I did some tests to see if i can narrow down the issue. I did an engraving test at 100mm/sec, 200mm/sec and 300mm/sec. I set an origin point, pulsed the laser (to mark the origin), clicked start and engraved the file. At the end of the print, the laser head goes back to the origin. At 100mm/sec - the head did not return to the same place, it was about 1mm to the right in the X axis (gantry left to right). The Y axis (front to back) was aligned. At 200mm/sec, it was about 1.5mm to the right and 300mm/sec, it was dead on. It is repeatable as I did 200 three times and 300 twice. In all three cases at 200, the gap was the same (about 1.5mm) and both times at 300, it was fine.
The controller thinks it’s in the correct position (based on the numbers in the controller and lightburn) after the engrave. If I reset the controller, the head goes back to the proper spot.
Here is what I’ve checked so far- the belt seems properly adjusted- snug, but not too tight. I’ve cleaned and greased the rail bearing and have marked the stepper motor sprocket where it press fits on to the stepper motor shaft to see if it’s slipping (it’s not).
I’m running a Ruida 644XG with RDLC-V8.00.50
Hopefully the experts here have some thoughts on what to check next. I initially thought it was a mechanical issue (slipping or something), but I’m thinking software or controller settings now.
I’ve put some photos of the cut path, the layout, controller settings and a pic of the before and after pulses at the three speeds. Thanks in advance for any help.
I have a very similar issue; when I engrave a line of text (using line, not fill), i have noticed the letters are not in alignment (some letters would be higher and some lower). I hadn’t noticed this in fill mode, probably due to the slower Y axis speeds. The preview looks good, and when I am cutting using line mode (again, low speed), everything looks fine. I will have to do some more experiments like Mike to confirm the speed relationship, but from what I see so far, he is on the money.
I am on the latest version of LB, Marlin on Ramps 1.4 with external drivers on a Chinese 90w CO2 converted from DSP to gcode.
It’s pretty strange- I’ve run for over a week, all at the faster speeds with no alignment issues. The head returns to the origin point consistently at 300mm/s. Unfortunately, I’ve found a few jobs I’m doing require me to slow it down and the only remedy I can find is to reset between cuts so the head returns to the origin before staring the next cut.
After scouring the forums and doing some testing, I think I sorted out the alignment issue and the losing of my origin position after a long engrave. I changed the PWM setting for the X axis From True to False, wrote it to the controller and ran a bunch of tests at different speeds. Everything lined up perfectly. Crazy it took me so long to sort this out as it was a setting from OM Tech from when I bought it. Just to verify, I switched it back and the problem re-appeared until I flipped it back to False.
Anyway, if anyone else has this issue, hope it helps.
