Hi Guys
I am trying to engrave a border around my project . but everytime I set the border in the fill under my set blue colour it wants to engrave the whole project .
can you advise where I am going wrong > ?
Hi Guys
Use the offset tool to draw a new border line just inside the border line you have. The larger the offset distance the wider the border will be.
run it as line just lower power and faster than you would do cutting. It will engrave just the line.
Or if you already have the border set up, boolean subtract the inside part from the outside.
When setting an object to ‘Fill’, LightBurn uses the boundaries of objects to toggle the fill on and off as shown in the images in the post below.
