Is this completely unheard of?
Imagine I have a rectangle, 24" long by 6" wide and the engraving area is only half inch all the way around.
Is there a setting to have the laser run the bottom first, up one side, across the top, and down the last side? In a clockwise type pattern
I hope this makes sense - having the laser head travel 2 feet for just a .5" engraving is a ton of unwanted time.
Thank you!
You mean it’s like a picture frame and you have a lot of travel time scanning one edge to the other?
You could do the fours sides as 4 layers or groups.
I can’t see anything in optimisation but I could be wrong.
A
edit: In layer settings you can change the scan direction so that it only travels the 6" gap not the 24"
This is precisely what Flood Fill was designed for. Don’t use it for really complex paths, because it starts to get really messy, but for a simple outline it’s perfect.
You can also split the frame using the new Cut Shapes feature, or the boolean tools:
I have an oval ring to be engraved for an inlay. In orer to save time I will remove the material inside with a mill after. But to have the correct external shape, I want to engrave a ring (2-4mm wide).
My oval ring is 45° looking downward. Even if I change the scan angle in the cut parameters, as I have one shape, it wants to scan it on “both” sides at the same time. This means most of the time spent is in travel. Engraving time ~35min and travel 460min!
Any help to optimize this engraving wou…
AlanRichard
(Alan Csizmazia)
August 10, 2020, 10:52am
4
Oh, flood fill!
I never spotted that button before!
Yet another cool function for just a single mouse click. Nice one.
A
system
(system)
Closed
September 9, 2020, 10:52am
5
