Engraving stamps settings - LightBurn Software
Hi I would like to create stamps with my CO2 laser but the outcomes are horrible. :disappointed:
I found this on the forum regarding stamps
But still the outcome is not usable.
Can somebody share tips and lightburn settings how to create stamps.
My settings:
Ruida 644XS
Speed: 300
Power max: 20
Power min: 0
Interval (mm): 0.1
Ramp length: 0.5
Ramp Outer edge: ON
Flood fill: ON
Or is it a material problem? I bought this on aliexpress
Don’t know the power of your machine but it seems to be cutting into the surface enough on 20%. anything under 8-10% (depending on machine) will not be enough to make the laser fire, but if you are just doing black and white image then that’s no issue.
I would remove the ramp completely, on such a small design having 0.5mm ramp is to much imo.
If I was doing it without testing I would use this :
speed 300
Max Power 20
Min power 0
interval 0.15 mm
ramp off
If you want to have the outer ring with a ramp, put that on a different layer and add the ramp effect back on.
This is probably more like what you want…
I have no clue what ā€œFlash Stamping Photosensitive Pad Sealā€ actually is…
Not knowing what the material you have is, I’d question it initially.
If you are ā€˜scanning’ a job, then min speed setting isn’t going to be a problem. It will, with a vector cut.
Good luck…
