Error 22 when i try to jog the laser
I have an ortur laser master 2 pro s2 . Using version 2 i got error 22 as soon i try move the laser . I downgrade to 1.7 version and everything works fine .
I ran into this myself. It is not picking up a default feed rate like it used to. The Feed rate is Modal, meaning it remembers it until you change it. Apparently on the first install, no Fxxx is sent to the laser on startup even if it Homes.
I sent F1000 to the laser using the Console window and it was fine after that. It seems Lightburn needed that too.
When I upgraded to 2.0.03, I did not see this happen, so it was likely fixed by then. It did not stop me from working, so I really do not know what cured it.
Maybe @JohnJohn has more info on this.
Checking! :smiley:
O installed 2.0.03 version but i soon as imove the laser i got error 22 feed rate not yet set , only homing works .
I found that if i go to additional settings and read from controller , i’have got no more error .
3 posts were merged into an existing topic: No se puede mover el cabezal. (The head cannot be moved)
