Kbryce
                    October 27, 2022, 10:33pm
                  1
              Hi, I keep getting error code 20 everytime I try to start the project Please help.
Here is what I see…
Starting stream
error:20
Unsupported or invalid g-code command found in block.
On or near line 2:
error:20
On or near line 4:
error:20
On or near line 5:
Stream completed in 0:00
ok
ok
ok
                berainlb
                    October 28, 2022, 12:37am
                  2
              Can you save the Gcode in Laser window using a .txt extension and then upload that file here for review?
              What laser cutter are you running (model name) and what process did you follow to set it up?
                Kbryce
                    October 28, 2022, 12:58pm
                  4
              I have the Ortur Laser Master 2. I had it working fine until I got code 20.
              Thanks! And has anything changed in your set up? Were you able to save that GCode for us to take a look at?
                JohnJohn
                    November 8, 2022, 11:23pm
                  7
                Kbryce
                    November 9, 2022,  4:23pm
                  8
              Here is the G-Code for the file. Nothing has changed, still same error.
Avery Cup.txt  (521.3 KB)
                JTR
                    November 9, 2022,  4:43pm
                  9
              It looks like you have Rotary Mode enabled and set to the ‘A’ axis. Try toggling Rotary Mode off. You can go to ‘Laser Tools’ > ‘Rotary Setup’ to find the switch, if you don’t have it enabled in your Laser window. If you are intending to use a rotary, it should be set to the ‘Y’ axis- that can also be controlled in the ‘Rotary Setup’ window.
                Kbryce
                    November 10, 2022,  4:09pm
                  10
              I fixed the axis and it is on Y axis, however when I sent it to burn, it is burning something other than what is on my screen. It is not the image I have in Lightburn. The image is stretched very wide with many lines.
Below is the G-Code
Avery Cup 2.txt  (3.0 KB)
                berainlb
                    November 10, 2022,  4:14pm
                  11
              Can you upload the .lbrn file that was used to generate the gcode?
                Kbryce
                    November 10, 2022,  4:16pm
                  12
                berainlb
                    November 10, 2022,  4:19pm
                  13
              I can’t correlate the g-code to the .lbrn file. What does Preview show you? Can you take a screenshot?
                Kbryce
                    November 10, 2022,  4:25pm
                  15
              It looks fine on my screen and in preview, but cut very wide and with vertical lines, not filled in.
                Kbryce
                    November 10, 2022,  4:29pm
                  16
              Avery Cup 3.txt  (3.3 KB)
Avery Cup 3.lbrn2  (42.6 KB)
Here is the G-Code again. and the Lightburn File.
                berainlb
                    November 10, 2022,  5:56pm
                  17
              When you’re running the job and saving the g-code, do you have all the relevant elements selected?
For some reason it looks like only the oval is being saved in g-code.
                Kbryce
                    November 10, 2022,  7:05pm
                  18
              The oval was the only thing I was cutting. I was making a test cut before cutting the rest. Previously I cut something else and it had the same effect, it was wide with vertical lines.
                berainlb
                    November 10, 2022,  8:32pm
                  19
              I don’t see any reason why the gcode would be generated that way from what’s available.
Can you take a full screenshot of LightBurn with the design loaded?
                system
                    December 10, 2022,  8:32pm
                  20
