culp46
(Alan Culpitt)
February 21, 2024, 12:13pm
1
I am trying to run an ortur laser master 3 using Lightburn 15.01
When I switch the machine on the head homes and then the power/status light holds green for about 4 seconds then switches to blue then yellow then back to green.
Im trying to set up a material test grid and to get the head to frame the grid it wont do anything
culp46
(Alan Culpitt)
February 21, 2024, 2:40pm
2
I have got it working by setting up a simple circle to cut. It distorts the circle see attached picture
I’ve recently updated to 1.5.01
It will cut a square of similar dimensions just fine
gilaraujo
(Gil Araújo)
February 21, 2024, 3:26pm
3
These are for the most part just reports
I would imagine wifi connectivity activity
What firmware version are you running on the OLM3?
as per circle your Y belts are loose
Can you take images of the belt tensioners both sides?
culp46
(Alan Culpitt)
February 21, 2024, 3:44pm
4
ahh! I found one of the belts had come out of the slotted hole on the carriage, I put it back in the slot and all is well!
Can I disable the wifi access? I dont use it as I have the LB set up in an outdoor shed and our wifi doesnt stretch that far
gilaraujo
(Gil Araújo)
February 21, 2024, 3:45pm
5
not totally, unfortunatlly so the blinking lights will always happen
culp46
(Alan Culpitt)
February 21, 2024, 3:46pm
6
oh right. Thanks for your help, much obliged
system
(system)
Closed
March 22, 2024, 3:46pm
7
